Old 11-24-2012, 05:39 PM   #11
49 34's Avatar
I'm not sure on the exact model, its the green one that's part of the Ryobi one+ tool set, it does both tires and air mattresses. It was like 40 bucks from home dept online.
Greg
49 34 is offline   Reply With Quote
Old 11-24-2012, 05:53 PM   #12
We run 80 PSI in the trailer and truck tires, tried several 12v units and they just would not inflate past 65 PSI. Bought a small Dewalt 120v from Home Depot and carry it in the bed of the truck. I have a TPMS and always check pressure before leaving home or the CG in case I need to top off a tire while I still have a/c power.
Sirsea is offline   Reply With Quote
Old 11-25-2012, 01:41 AM   #13
49 34's Avatar
I should have added that with my various trailers hooked up I use mine to fill up my old school gabriel air shocks on my truck sometimes up to 150 lbs to level my truck since thats the max pressure and it goes to and it has no problems.
Old 11-25-2012, 02:09 AM   #14
I am shopping around now for a compressor. The Solera will have 6 tires, the ATV trailer 2. That makes 8 full size tires.
Two ATVs plus two motorcycles is 12 smaller tires.
One of the ATVs has a cigarette lighter. I have a small 12v compressor that I keep in the ATV storage compartment. That will suffice for the toys, but is way too small for the Solera and ATV trailer tires.
I will likely be looking for a pretty high CFM unit. That will likely be 120 volts.
Wayne in Coarsegold near Yosemite
2013 Forest River Solera 24R
2014 Jeep Wrangler Rubicon
ATV trailer for the following toys
2008 Yamaha WR250R,2009 Honda CRF150F
2008 Polaris Scrambler 500
PopBeavers is offline   Reply With Quote
Old 11-27-2012, 04:34 PM   #15
Rick R's Avatar
I carry a 12 volt compressor, purchased at WalMart, but I find a good full sized bicycle tire pump to be faster for just adding a few pounds to the tire. If it is flat you are going to put on a spare and have the tire repair place fix and fill it anyway.
Rick R is offline   Reply With Quote
12 Volt
