Old 09-01-2014, 05:09 PM   #1
Relkinsa's Avatar
2nd Axle Bearing Failure (Moved From Another Thread)
I am sitting in North Little Rock with my now second bearing failure with flames coming out around the brake drum. One last Oct and second one today 9-1-14. I am very concerned about Lippert axles.
Relkinsa is offline   Reply With Quote
Old 09-16-2014, 08:13 PM   #2
MtnGuy's Avatar
Big time bummer !!!
Just curious: Had you checked the grease ?? Also, were the hubs running hotter than the others at your last stop ?? How old is your trailer, and how many miles on it ?? Inquiring minds want to know.
That type of information can be useful for other members (me included ).
Old 09-18-2014, 03:16 PM   #3
Relkinsa's Avatar
Lippert axles
Our Lacrosse 301RLS is 3 1/2 yrs old. Our second Lippert Axle that just burnt up was packed 10 months ago. This one has taken 2 1/2 weeks to get to Camping World from Lippert. I just don't have much confidence in Lippert or their axles at this point. Lippert told me by phone that they don't consider lubing the bearings by the grease fitting in the end as "maintenance" for the bearings. So one has to wonder why they have the grease fitting there. Still confused on this wheel bearing issue.
Old 09-21-2014, 10:08 PM   #4
LKicklight's Avatar
Lippert vs Dexter
We recently lost a wheel bearing on a Lippert Axle, 2 1/2 years old, bearings clenaed, inspected and greased jusy 4 months ago befor journey to Alaska. Now have the original Lippert Axles and four new Dexter Brake Assy's...The Factory has switched to Dexter Axle's and Brakes on some models I understand..
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 09-22-2014, 07:57 AM   #5
This is true my 2014 325res has the Dexter Axles hope they are as good as advertised. I still do the old touch test every time I stop I check every tire and hub on both the 5ver and the Truck.
2014 Crusader 325res Touring Edition
2003 Silverado Duramax 6.6 Dually Longbed 2wd Crew Cab
RickV is offline   Reply With Quote
Old 09-22-2014, 08:35 AM   #6
I have a 365 saq and just had my axles swapped out. I had alko and fr just put on dexter axles. I think dexter are better axles. I know that they have better brakes.
chiro is offline   Reply With Quote
Old 10-04-2014, 01:53 PM   #7
You can bet your last dollar that it will never be lippert's fault if you have a failure with bearings or brake hubs. I found on my first bearing inspection ( trailer 1 year old) 3 out 0f 4 outer race turning in the hub, of course Lippert said it was my fault I was late two months on my inspection. They can kiss my grits.
Gee Whiz is offline   Reply With Quote
Old 10-04-2014, 01:54 PM   #8
Oh! Yea i replaced my brake hubs with dexter....
Old 10-13-2014, 10:01 PM   #9
Ret E-9 Anchor-clanker
donanddona's Avatar
Yes I have had my time of burnt bearings also on alco Lippert axels.. I now replace inner and outer bearings on both axels every spring. Hand packing is the best. As a full timer I tend to travel, and lubing via the grease zert will only keep me happy spring to fall (most miles). Last year I replaced all bearings and bearing races. If your pressing grease through the zert and the grease drips out (don't hold together). Your bearing are bad.
ID:	64703   Click image for larger version
ID:	64704   Click image for larger version
ID:	64705   Click image for larger version
donanddona is offline   Reply With Quote
Old 10-13-2014, 10:26 PM   #10
Evereddie's Avatar
Is that grease in the photo the one to use?
Evereddie is offline   Reply With Quote
