2x7,000lbs axles w/Carlisle ST235/85R16
We have a 2013 Sanibel 3600 5th. The GY Marathon ST235/80R16 were at 100*f after 75mi pull on a 50*f day. The GY Marathons derate the 7,000lbs axles to 6,840lbs. each, as stated on the axle weight card on the coach. Has any one changed to the Carlisle ST235/85R16 E load rated tire, rated at 3640lbs @ 80psi? Looking to replace the GY tires.
Tire shop wants to use the balancing beads in the new tires. Any one out there have long time towing with the beads?
2013 Sanibel 3600 5th, 2007Dodge 2500 Cummins Turbo Diesel, 2WD, 4.10gears, Banks equipped, 18" factory rims
