Old 09-27-2014, 07:35 PM   #1
GLCM Warrior
Lefty59's Avatar
5'er Landing Gear Question
I'm wondering whether it is important for the two landing gear legs to contact the ground at exactly the same height or if the difference in contact height (max 1"?) could cause a problem. Our usual method for engaging the landing gear is to pull both pins, let both feet rest on the ground/blocks, then raise the gear until first one, then the other landing gear leg locking pin locks into place.
When on uneven ground, do you place a spacer under the 'shorter' landing gear leg to take up the gap or just lift the trailer until the shorter leg locks in?
I'm asking mainly to determine if purchasing an adjustable landing leg foot (LANDING LEG FOOT) is worth the $$.
Thanks for any input.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 09-27-2014, 08:05 PM   #2
wfmdfm's Avatar
I try my best to make sure they both have the same gap from the leg to the ground. Most of the time I can get this with a 2 x 6 block and the leg adjustments. I do keep one 3/4 board for the odd chance that I cant get it. I did damage one of the legs early on and I think it was from not having a even gap so lesson learned.
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 09-27-2014, 08:07 PM   #3
davel1971's Avatar
I use different board thicknesses to take up the difference
David & Lynn
Old 09-27-2014, 08:15 PM   #4
asquared's Avatar
We use our lynx leveled to even up underneath. We try to keep the legs on the same hikes if we can and have them hit the blocks at the same time.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 09-27-2014, 08:16 PM   #5
B and B's Avatar
I use a landing pad made out of composite for under my feet on the trailer. I have a piece of 3/4 inch plywood to put under a foot that doesn't touch fully. Easy solution.
I also have JT strong-arms on the trailer so changing to a adjust foot is not possible.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 09-27-2014, 08:35 PM   #6
The owners manual for our rig say to extend the landing gear about 1/2 way down then pull the pins and let the pads drop to the ground, lift up until they lock in the first hole and add shims as necessary if one is higher than the other so they both contact the ground at the same time.
Sirsea is offline   Reply With Quote
Old 09-27-2014, 09:33 PM   #7
B and B's Avatar
One thing that not many know about is the grease fitting at the top of the gear inside. Needs to be greased.
Old 09-27-2014, 09:40 PM   #8
asquared's Avatar
I have been looking and looking for this. I have yet to find it.
2014 Sabre 34REQS-6
Old 09-27-2014, 09:48 PM   #9
B and B's Avatar
Mine are on th back side towards the back wall, they are painted black like the rest of the gear is, I saw it when mount hangers for the cables.
Old 09-27-2014, 09:55 PM   #10
asquared's Avatar
I will have to get in there with a light and really look. We have looked and looked and felt with hands and just can't find them. Also, what can you lube the drop down section with? A dry Silicone spray? Ours stick a little when DH tries to adjust them.
2014 Sabre 34REQS-6
5er
