Old 07-17-2014, 09:32 PM   #1
Nick M's Avatar
5er landing gear questions
I have a 2010 Brookstone 360RL that is giving me problems. It doesn't want to lift the hitch pin high enough to engage my hitch. As I raise the camper, the motor begins slowing down (on shore power) and finally the gearbox begins chattering and it refuses to go any higher. I can attach the manual crank and with another person holding the extend switch I can raise it manually.
1. What locks the landing gear at any height?
2. Can I remove the motor and gearbox without fear of the legs retracting?
3. How can I identify the manufacturer of the landing gear, motor and gearbox?
Thanks in advance for your help.
Nick
WB4SQI
Nick, Sharon and Finnigan
Nick M is offline   Reply With Quote
Old 07-17-2014, 09:40 PM   #2
QCCowboy's Avatar
Not sure if this will help or not, but we don't lower the camper onto the hitch. Simply get the hitch high enough and the back the truck into it. The truck will squat and the hitch engages.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 07-17-2014, 09:44 PM   #3
Sounds more like your battery(s) are gone. Before you mess with the motor, try putting a GOOD full charged battery on it. Don't rely on the converter or the batteries in the unit.
Old 07-17-2014, 09:46 PM   #4
BamaBob's Avatar
X2!
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 07-18-2014, 05:54 AM   #5
Herk7769's Avatar
Are you at "end of travel"? This has happened to me before when I was parked on a slope.
The truck loaded allowed me to drop the adjustable part of the legs to the ground and disconnect, but I was very near the full extension of the motor driven part of the landing gear by the time I had enough weight off to disconnect.
When I went to hook up, I could not get enough altitude to back the truck into the hitch.
I had to use wooden blocks to support the frame so I could get more of the adjustable part down.
I extended the landing gear as far up as I could; blocked the frame on both sides and retracted the landing gear a foot or so; then dropped the legs again until they hit the ground. I re-pinned them; extended the landing gear to lift the frame off the supports and connected normally.
Now, when I am on a slope, I always plan ahead on how much "leg" to drop so I have full use of the motor driven part when I need to connect.
HAM CALLSIGN - KC3FFW
Old 07-18-2014, 05:56 AM   #6
Originally Posted by HSVBamaBob View Post
X2!
Pretty sure he said he was on shore power. Batteries should not be an issue at that point.
At least they are not on my W&P.
036.6turbo is offline   Reply With Quote
Old 07-18-2014, 06:21 AM   #7
TURBS's Avatar
I concur!
Old 07-18-2014, 06:28 AM   #8
The if the battery(s) are bad/dead, the landing jack motor will not receive enough power to work to full power off the converter alone. Disconnect your batteries and try it.
Old 07-18-2014, 07:02 AM   #9
camper1999's Avatar
X2 if the battery is dead land gear and slideouts will not work properly even if plugged in.
2011 GMC 2500HD Diesel
Old 07-18-2014, 07:40 AM   #10
Witch Doctor's Avatar
I always extend my legs down about 4" or so depending on the spot, then drop the legs. My driveway slopes down so I learned that I need that 4" to level the unit off. If I just pull the pin there is noway to drop the unit front end to make it level. So I really now just do it all the time.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
5er
