Old 04-28-2016, 10:49 PM   #11
farmncamp's Avatar
I also added the firestone airbags to my F350. I added the compressor and the single air switch. If I were to do it over again, I'd get the dual air where you can control pressure independently in each bag. This is to eliminate the bags "sharing air." An example would be turning a corner and the truck leaning to the right in the turn. The right airbag would compress and therefore "share air" with the left bag that has less load. The problem only occurs when you use the single air command option. The dual air or no compressor option does not have this issue. I added a big hellwig swaybar and this fixed the occasional excessive lateral roll.
2015 Coachman Chaparral 360IBL
2012 6.7L Ford F350 SRW
53 nights camped in 2017.
farmncamp is offline   Reply With Quote
Old 04-28-2016, 11:01 PM   #12
I have the Airlift also on my 2014 F-250, long bed crew cab 4x4 and have zero problems. Was going to get the Firestone but our local truck accessories store had the Airlift in stock. Having looked into both in detail, even talking to people who had either, there isn't a lot of difference in the two. No compressor and I'm running a single inlet for both bags. I think you'd be ok with either.
2016 Salem Hemisphere 356 QBQ
2014 F-250 Super Duty
Josey is offline   Reply With Quote
Old 04-30-2016, 11:44 AM   #13
Put Firestone bags on my F150 with manual fill. Took no time to find that wasn't good and put the Air Lift 72000 wireless control and compressor on. I wouldn't go without an on board compressor again.
Carrier is offline   Reply With Quote
Old 04-30-2016, 12:31 PM   #14
john5646's Avatar
Firestone bags. No question. You will be happy. Click image for larger version
Name:	ImageUploadedByForest River Forums1462037352.102826.jpg
ID:	106520Click image for larger version
Name:	ImageUploadedByForest River Forums1462037394.241534.jpg
Mine on a Titan.
You will love it.
I did not do on board compresser. I carry battery powered portable. But find home fill works 90% of time.
john5646 is offline   Reply With Quote
Old 04-30-2016, 12:42 PM   #15
Capt. Mike's Avatar
Originally Posted by Ramrod79 View Post
I have the firestones on my F250, they make for a really nice ride with the fifthwheel hooked up. Run about 10psi unloaded and 40psi with the fifthwheel on. I ran the airlines inside the fuel door so I can reach it with my little 12v compressor. Installation was about 3.5hrs to install.
Ramrod79, apparently your 12v. compressor gets the job done OK inflating them to 40 psi?
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
It's not how old you are, it's how you are old.Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 04-30-2016, 03:00 PM   #16
Done with this
Originally Posted by john5646 View Post
Firestone bags. No question. You will be happy. Attachment 106520Attachment 106521
Mine on a Titan.
You will love it.
Yep!!
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 04-30-2016, 03:36 PM   #17
DaGrinch's Avatar
Had Firestones on my '04 Grand Cherokee and installed a set on my '12 Armada. Worked great on both vehicles. Ran about 15psi when not towing and about 35-40psi when towing. Never had a problem.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
air bags
