04-04-2017, 04:47 AM
Adjusting Torsion Axle? Mini-Light need more clearance
Rockwood Mini Light has very poor clearance.
Are there lift kits?
Can I get more height from Torsion Axle?
Thank you,
M-Bob
04-04-2017, 04:54 AM
Here is one thread....
http://www.forestriverforums.com/for...ise-64594.html
If you do a search for "lift kit" above, you will get more threads.....
Fonzie
04-04-2017, 05:01 AM
Originally Posted by fonzie
Good Info! Youroo!!
04-04-2017, 06:58 AM
Thanks guys. Got fooled, thought that I could just reverse springs to top of axle for much added clearance but, that trailer has a Torsion Axle.
Did call a local RV repair place here yesterday and the gentleman said that, "it would cost around 25 hundred dollars to lift." That's crazy.
Today checking out more options.
That Mini Light should have been manufactured with better clearance.
It's the lowest trailer that I have seen on the roads.
Low Rider!
Thank you all,
M-Bob
04-04-2017, 07:17 AM
Georgia Rally Coordinator
Low Rider!
Thank you all,
M-Bob
Guess you make your TV a low rider to match tt.
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
04-04-2017, 07:41 AM
Sounds like the repair guy wanted to sell you a set of axles with a steeper down angle. That's one way of gaining more clearance, but if you only need a couple of inches the lift kit is quick and easy, and a whole lot less expensive.
Gotta go campin!
04-04-2017, 01:07 PM
Our 2012 Rockwood travel trailer had the same problem - our driveway is sloped and the rear stabs would hit the pavement. Our axles were made by Al-Ko; a call to Forest River got the parts and we had a local heavy track shop do the installation; the labour was around CAD 800.
Before:
After:
The lift kit:
No problems with the driveway now.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
04-04-2017, 03:08 PM
Things are moving along well -- thank you all for your posts and pictures.
Called even a closer by RV repair shop today and they said that, "they could custom make some brackets and install for between 8 hundred to 1 thousand dollars.
Getting there -- thank you,
M-Bob
04-30-2017, 08:31 PM
Im not sure who makes the axles that are under your trailer. My previous trailer was a Starcraft and had Dexter torsion axles under it. The shoul dhave a label or tag on the backside of the axle tube with a model number on it. I called Dexter with the part numbers from my axles and purchased the correct kit direct through them for under one hundred bucks. The hardest part of the install was jacking and supporting the trailer high enough so the wheels could be put back on after the lift was installed. You will also probably need to reroute the brake wires due to the assembly being further from the frame after the lift brackets are installed. I did it in my driveway on a Saturday. I did the alignment myself with a tape measure. Not a bad job at all.
05-01-2017, 08:55 AM
I found mine on our first trip with the new-to-us trailer...
