Old 02-20-2012, 06:44 PM   #11
Thanks everyone. I got down there again tonight a hit it a little more with a hammer. Nothing. I tried a torch... nothing. Tried rocking it, nothing. Soo... I called Good Sam. Dude will be out in the morning. We'll see. I'll keep you posted.
Brian
2000 Forest River Reflections 327s DP
Toad = 2009 VW Tiguan.
Coupla bikes, coupla dogs, coupla 30-somethings wishing they were retired.
Prepilot_3ck is offline   Reply With Quote
Old 02-20-2012, 06:52 PM   #12
j2detroit's Avatar
You need to clear the lines and add air line anti free to your system so it won't happen again you should be able to get it at a truck stop or auto parts store may have it the store I work arcarries it so I would assume others should
j2detroit is offline   Reply With Quote
Old 02-20-2012, 06:55 PM   #13
Hob
One other thing, while the mechanic is there have him show you where the water drain petcock for your air tank is located. That needs to be opened and drained about every other month.
Best Regards,
Hob
Hob is offline   Reply With Quote
Old 02-27-2012, 04:06 PM   #14
Okey dokey, just wanted to follow up with all of you seeing as you all were so helpful on this. I gave up, called in local repair place. They broke one of the drums, but broke everything else free. They replaced the drum and I'm off and running. They said it was the WORST they've ever seen. So, there it is. $650 later and I'm rolling...into the shop for engine work.
Old 02-27-2012, 04:33 PM   #15
TURBS's Avatar
Perfect
brakes
