Old 07-15-2016, 08:24 AM   #1
Air Compressor
Would you consider an air compressor to be "essential" to have in your TV or TT at all times?
If so, can you recommend a particular make/model?
Thank You!
Seakayaker
Charleston, SC
2016 Silverado 1500 LTZ
2016 Wildwood 27RKSS
seakayaker is offline   Reply With Quote
Old 07-15-2016, 08:25 AM   #2
Scrub175's Avatar
I would therefore I'm looking at compact options as we speak.
Scrub175 is offline   Reply With Quote
Old 07-15-2016, 08:31 AM   #3
banda's Avatar
I always carry one. I have one of these and love it!
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
banda is online now   Reply With Quote
Old 07-15-2016, 08:54 AM   #4
Do you carry an extra long hose in order to reach TT tires?
Charleston, SC
Old 07-15-2016, 09:16 AM   #5
Scrub175's Avatar
I might go with this one since I use the Ryobi cordless drill for stabilizer jack deployment and already have several batteries.
Name:	ImageUploadedByForest River Forums1468588558.906001.jpg
Name:	ImageUploadedByForest River Forums1468588533.020252.jpg
Old 07-15-2016, 09:24 AM   #6
Kenny kustom's Avatar
Viair 400PRV
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Old 07-15-2016, 09:24 AM   #7
nomad297's Avatar
I consider it essential, so I carry the VIAIR 450P, which is an excellent 12 volt compressor. You can also get the 450P-RV which comes with extra hose and additional tools required for some RVs. I didn't need the RV version, but I bought an additional section of hose.
Bruce
Old 07-15-2016, 09:31 AM   #8
banda's Avatar
Yes.
Old 07-15-2016, 09:33 AM   #9
clr
I carry a Porter-Cable CMB15 1.5 gallon oil-free shrouded compressor with a 50 ft hose in my 5th wheel. Just make sure that you get an oil-free compressor with a max PSI rating that is above your tire requirement with sufficient air flow at your required tire pressure so you are not there for 10 minutes filling each tire. Many of the small compressors only put out .7 SCM or less at max pressure. The CMB15 does very well with my 125 PSI max tire rating, a good unit at a reasonable price.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 07-15-2016, 09:41 AM   #10
Air Compressor
[QUOTE=nomad297;1259316]I consider it essential, so I carry the VIAIR 450P, which is an excellent 12 volt compressor. You can also get the 450P-RV which comes with extra hose and additional tools required for some RVs. I didn't need the RV version, but I bought an additional section of
X2 When your trailer tires need 110# this pump rocks
jalvin is offline   Reply With Quote
