Old 01-24-2015, 12:15 PM   #1
gashog's Avatar
Airing up TT tires while out on the road
I monitor my tire air pressure with Tire Minders and make sure they always have the correct air pressure. Never needed to add air in my TT tires while out traveling. If your out and need air in your TT tires what do you do? Most if not all gas stations don't have air that's easy to get too with your TT. All the portable air compressors that I've owned and seen plug into your cigarette lighter and will barely reach the tires on the tow vehicle never-less your TT. What portable air compressor do people use that will reach their TT tires?
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 01-24-2015, 12:32 PM   #2
jevanb's Avatar
I throw in the basement a pancake compressor or a 10 gal portable tank that is filled before I leave home. But my truck has a compressor for the air bags what will also do in a pinch, so 115v compressor while i have shore elect, 12v truck while on the road, and a crappy 12v cig for whenever, and a fully aired 10 gal tank.
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 01-24-2015, 12:50 PM   #3
caper's Avatar
You could install a marine 12 volt outlet on each side of the trailer at each wheel well. Then no problem using the portable 12volt compressor.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 01-24-2015, 01:05 PM   #4
Rivnut
Rivnut's Avatar
I extended my portable air compressor by adding a length of lamp cord and adding a marine 12v socket at the tongue jack area. Covers all tires. Check em every day, or pay the bill.
Rivnut is offline   Reply With Quote
Old 01-24-2015, 05:05 PM   #5
PSUFan1's Avatar
This is what I use, plug inverter in the truck with an extension cord to plug the air compressor.
Name:	ImageUploadedByForest River Forums1422140663.184209.jpg
Tim & Tracy, Jennifer (15), Alyssa (10), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
Old 01-25-2015, 12:20 PM   #6
bob213's Avatar
I like the 12V models that hook direct to your battery.
Amazon.com: VIAIR 90P Portable Compressor: Automotive
Walmart has the "88" model shipped to the store for $70.
Between cord length and air hose length it reach all tires. Air hose extension is available also.
You can avoid reality, but you cannot avoid the consequences of avoiding reality Ayn Rand
bob213 is offline   Reply With Quote
Old 01-25-2015, 12:35 PM   #7
BigTJohn's Avatar
I got a ViAir 400P 12vdc off Amazon , it read as a "used" unit but came in orig box and looked brand new. It fills the tires on truck, trailer with no problem. I made an extension power line from the trailer battery to reach the tires and this is very easy to use as it puts the power switch right at hand when using the compressor.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 01-25-2015, 02:27 PM   #8
Send a message via Skype™ to stillontheroad
A very inexpensive option to to go to walmart and buy a 12 volt extension cord with a cigatette lighter plug on one end and a female connection on the other.
stillontheroad is offline   Reply With Quote
Old 01-25-2015, 05:08 PM   #9
We carry a dual tank Campbell Hausfeld 120 volt compressor. Will go to @ 110 psi. It is light and easy to carry. Have tried the 12 volt ones but they seem to take forever.
VMI'62
Edmund is offline   Reply With Quote
Old 01-25-2015, 05:29 PM   #10
kho6658's Avatar
I use the Stanley FatMax Professional 1,000 Peak Amp Power Station. Take about 10 minutes to top off 4 tires.
Stanley PPRH5 Professional Power Station - Walmart.com
2016 Freedom Express 28SE
2017 F350 Lariat
Days Camped 2018 - 6
Days Camped 2017 - 41
kho6658 is offline   Reply With Quote
tire, tires
