Old 07-29-2012, 09:52 PM   #1
RONSTAR911's Avatar
Alco Torsion Axle mounts sheared off!
My Camping season ended yesterday when my 2009 Palomino Banshee Tent trailers axlel tore away from the frame and jammed my wheels into the fender wells, I had to get it towed home on a flat deck a hundred miles back to home. I found one other thread on here about the mounts cracking but I guess mine went all the way. Im assuming I will have to replace the entire axle, but wonder how this happened? If I was overloaded (probably the case) can i put the next size one in so this does not happen again. Its a single 3500 pound Alco Torsion setup with 15" "offroad" tire and ride height. here are some pictures. let me know what you guys think.
1. is this a known weak point on these axels?
2. do you think the manufacturer will do anything for me?
3. where is the cheapest place to find replacement axles?
Thanks everyone
Ron Y
Delta B.C.
ID:	17254   Click image for larger version
2009 Palomino Banshee B1 Off Road,
TV: 2004 Chevy Tahoe LS 4WD.
RONSTAR911 is offline   Reply With Quote
Old 07-29-2012, 10:09 PM   #2
Thanks everyone
Ron Y
Delta B.C.
Never heard of it before, but looks like the bolts were not torqued.
Old 07-29-2012, 10:53 PM   #3
RONSTAR911's Avatar
Yes I wondered about that myself judging by the way it pulled out like that. I pulled out the alco owners manual and sure enough it says every 6000 miles/ 6 months these bolts should be checked and retourqued to spec. WHO KNEW THAT? I doubt the thousands of people who own these axels on their trailer know they should be checking the mounting bolts! . That even makes me more frustrated because Im mister preventative maintance when it comes to my trailer, knowing it may have been prevented by me checking them once in a while makes me sick.
Old 07-30-2012, 08:10 AM   #4
TURBS's Avatar
Wow that's weird how that tore away !
Old 07-30-2012, 08:55 AM   #5
With the bolts not being torqued, the shock load of the torsion axle transmitted to the mounts will accelerate the metal fatigue. Once it gets to approx. 0.015" to 0.030" clearance, it accelerates much faster and when it gets to 0.25", all hell breaks loose.
Old 07-30-2012, 09:02 AM   #6
Triguy's Avatar
I, for one, did not know that. Thanks for the warning.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 07-30-2012, 09:23 PM   #7
MIKE44460's Avatar
Excuse me. The bolts are intact, the top photo shows the metal ripped around the, and the lower photo shows the metal tearing at the weakest point, the bend. Look how far the centerline of the axle/wheel is from the point of movement in the tube with the rubber springs are located. The wheel had a lot of leverage and the weakest points failed.
I was under my RV last week and I see things that have me scratching my head.
Mike & Lu Anne
& our Jack Russell 'Genny'
2011 Flagstaff 831FKBSS
2011 Chevy CC Duramax Z/71
OH plate GM DMAX
Hensley Arrow
MIKE44460 is offline   Reply With Quote
Old 07-30-2012, 10:21 PM   #8
Both photos show where the axle was shifting (shined metal around the washers) and the top picture shows where it tore around the hole and twisted.
Old 07-30-2012, 10:55 PM   #9
acadianbob's Avatar
Wow! I've got 25,000 miles on mine and have pounded the crap out of it on some very rough roads. I better check!! THANKS!!
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 07-31-2012, 08:13 PM   #10
RONSTAR911's Avatar
Well, I'm pretty sure that the design is flawed. There should be a heavier bracket or extended farther to offset the pivot point as the other gentleman pointed out the swing arm is very far back compared to the location of the bracket. Either way I have to fix it And prevent it from happening again. I'm considering upping to the 4000 pound model although it still uses the same bracket setup.
axle
