Old 08-20-2012, 06:25 AM   #1
All Kinds of Jack Pads
We are scheduled to pick up our Georgetown xl 378 in the next week or so. There are automatic Lippert levelers installed which should make set up at a "new" campground easier.
I am overwhelmed by the choices of jack pads available in the market from polypropylene breakables to heavy duty outrigger truck stabilizers to Hoss pads.
Can anyone tell me what I need. There may be gravel or grass set ups at many sites so a stable platform seems like a necessity for the fridge and leveling the unit. Many places require pads to avoid damage to the RV pads they have in place.
What have others bought for their units levelers?
___________________
Alan in Coral Springs
Georgetown XL 378TS 2013
Jayco Greyhawk 31ds 2012
Alan JS is offline   Reply With Quote
Old 08-20-2012, 12:58 PM   #2
Dallas Texas
TexasBBQ's Avatar
I've used the square orange pads that you can find at Walmart or on Amazon for about 30-35 bucks. I've not had very good luck with them but several other campers like them a lot. I 've destroyed several of them when they slide on asphalt when backing the trailer over them. Even the front levelers have deformed them when used on soft ground.
I ended up going to the hardware store and buying a 2x10 peice of cedar. I made a few pads for the levers and a couple long peices for the wheels in case I needed to lift one side a lot. I cut 45° angles on those. They don't slide on any type of pavement. I spent less than 1/3 the cost of those orange pads.
I chose cedar because it's very light weight.
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 08-20-2012, 01:31 PM   #3
Thank you Texas. Some of the pads advertised are very expensive and can cost 60-70 dollars. That seems like way too much for a piece of rubber..
I definitely don't want something that will crack apart with minimal usage.
___________________
Old 08-20-2012, 01:33 PM   #4
funkyJunk's Avatar
I use these on the front:
D1515.75 - Light Duty - Outrigger Pads
And I rarely use anything on the back 4 unless it is on grass or mud. If I do use anything it's just a few linx levelers on the back. Seems to work fine.
2013 Palomino Columbus 385BH
2011 Ford F350 DRW 6.7
funkyJunk is offline   Reply With Quote
Old 08-20-2012, 02:39 PM   #5
I cut (4) 2 x 10" x 12" long and lag bolted them to the existing trailer pads front and rear and leave them on all the time. Works good on grass, gravel or concrete.
Cheap and no storage problems.
Old 08-20-2012, 02:57 PM   #6
Rv leveling,,RV Accessories leveling pad leveling blocks camping jacks trucks | eBay
These were on ebay and price included 4 pads. They seemed thich enough and not brittle like plastic. There should be flexibility for different surfaces I would guess. But rather pay in the 30's.
___________________
Old 08-20-2012, 04:29 PM   #7
Dovetail's Avatar
Nice idea, gonna do that.
Rick and Linda, Lindale, TX
2011 Flagstaff 8528 CKSS
2006 F350 SW
Camping nights 2013: 130
Camping nights 2014: 17
Dovetail is offline   Reply With Quote
Old 08-20-2012, 04:46 PM   #8
Just be sure you use treated lumber.
Old 08-21-2012, 08:29 PM   #9
Dallas Texas
TexasBBQ's Avatar
X2
2004 Cardinal 33CKT
Old 08-22-2012, 07:15 AM   #10
All the jack pads using rubbber bases which conform to the ground make so much more sense . Having brittle pieces of plastic compounds only, are sure to crack , bend, or break with repeated usage.
Not being mechanically inclined I think we will invest in the 1" rubber Hosspads (8 1/2 " X 8 1/2 ") under a set of Camco squares which would also serve as wheel chocks.
I realize that not every camp site is a cement pad perfectly level.
___________________
Old 08-22-2012, 07:51 AM   #11
Have used 2x10 treated lumber pads for at least 30 yrs on every imaginable surface and never had one break. On a 5er, the rubber pads will put a excess amount of strain on the landing jacks when checking to make sure your latched. The rubber will not slide.
Old 08-22-2012, 08:19 AM   #12
Our group uses Lynx Levelers. If the ground is soft, a 2x8 goes under them. For leveling side to side, a combination of Lynx Levelers and lumber is utilized. If you use lumber, be sure to cut the edge on a 45* angle. It coule be a costly mistake not to
2006 Ram 2500 CTD
2011 Sabre 31RLDS
awjoker is offline   Reply With Quote
Old 08-22-2012, 08:22 AM   #13
Same here for leveling the trailer, but the OP was talking about the jack pads themselves, or at least I thought he was.
Old 08-22-2012, 08:32 AM   #14
I understand what you mean by not allowing the jack strut to adjust as it descends. If there is too much friction it will put strain on the mechanism. I will place an inexpensive Camco pad on top of the rubber base so it can move about as it begins to bear load.
What do you mean about being "latched"?
___________________
Old 08-22-2012, 08:46 AM   #15
On a 5er, once you latch the hitch, you need to raise the landing gear very slightly, set the trailer brakes and try to pull forward to make sure the hitch actually latched. This means the landing pads have to slide a little until the trailer brakes engage.
Old 08-22-2012, 09:54 AM   #16
I was too. The side to side comments was an add on. Lynx Levelers under the jack pads.
2006 Ram 2500 CTD
2011 Sabre 31RLDS
