Old 08-01-2015, 10:33 AM   #1
asquared's Avatar
another tire pressure question
We have constancy ly188 tires these are an ST load range E And speed rating L with max psi 80 cold. They are ST235/80R16 The tires are rated to 3520 lbs each and are filked with nitrogen. My fiver weighs 12380 lbs total loaded Wright. 2620 lbs of that is pin weight. Should I be running at 80 psi or lower? If lower, what should I be at? I know these are China bombs but trying to avoid a blow out on the way to Goshen without putting on new tires right now. Thanks.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 08-01-2015, 12:11 PM   #2
jriddering's Avatar
80 psi to get your full load rating for your tires.
Jim and Carol
2012 Crusader 290RLT
2010 Ford F-250 King Cab Diesel
Harley Davidson Edition
jriddering is offline   Reply With Quote
Old 08-01-2015, 01:39 PM   #3
Jerry01's Avatar
My opinion is to run them at max pressure all the time since underinflated tires are probably the number one cause of blowouts. Jerry
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
Old 08-01-2015, 02:36 PM   #4
asquared's Avatar
That's what I was thinking, just wanted to double check. Thanks.
2014 Sabre 34REQS-6
Old 08-02-2015, 12:02 PM   #5
rsdata's Avatar
X2
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 08-02-2015, 12:11 PM   #6
Should I Run Maximum PSI Rating on Trailer Tires Even When Carrying Lighter Load | etrailer.com
2006 Honda Goldwing
2012 Toyota Tundra DC
2015 Cherokee Grey wolf 19RR Limited
bluewoo is offline   Reply With Quote
Old 08-02-2015, 12:34 PM   #7
jtownstumpjumper's Avatar
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
Ran our MasterTracks at 80 psi last week on the way to the Nashville rally....6 hours at 63-65 mph with one 20 minute stop....TPMS readings showed they never got over 89-90 psi with a temp never exceeding 106-107 degrees....heat fluctuated sometimes due to which side the sun was hitting us.
Lloyd & Kathy & Kit(19 yr old cat)
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014 - 38 nights/3500 mi.; 2015 - 66 nights/6260 mi.; 2016 - 44 nights/6106 mi.
2017-65 nights/6992 mi.; 2018-7 nights/1037 miles....9 nights booked
jtownstumpjumper is offline   Reply With Quote
Old 08-02-2015, 02:13 PM   #8
I am glad that someone observed the high temp on the "sunny side " of your vehicle. I had noticed that my 5er tires would vary in tire temp from one side to the other. My only explanation was that was always the side the sun was hitting. ..But I did not want to believe.
Has anyone else observed this???
Sam C.
2011 Bighorn
2011 3500 crew cab
samcunningham is offline   Reply With Quote
Old 08-02-2015, 03:39 PM   #9
Of course, it always hotter in the sun than the shade. I left Yellowstone a few days ago and it was in the low 50's outside. The shaded tires were both at 50 degrees and the sunny tires were both at 70 degrees. The sun had been out for a few hours.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 08-02-2015, 04:15 PM   #10
Max PSI with ST tires.
phillyg is offline   Reply With Quote
pressure, tire
