Old 05-05-2012, 09:48 PM   #1
fast murray's Avatar
Another Tire Question
I've learned that the tires on our 04 5er were actually made in 03. They are General ST225 75r16D. I had to replace one of them last fall with a Goodyear Marathon tire from China. I've thought about simply buying 3 more of them but am not hearing too many positive things about them. Of course I've been looking around at the Maxxis tires but would it be of any benefit to go to a E rated tire? If so, would they need to be run at max pressure like is suggested of trailer tires? I currently run the D's at 65psi as I read on this site.
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 05-05-2012, 09:58 PM   #2
acadianbob's Avatar
If you are near the maximum capacity of your LR D tires, then E rated tires may be of benefit. I would not be afraid of Goodyear Marathons. I had a set that performed perfectly. You do not need to run your tires at maximum pressure but reducing pressure will reduce the rated capacity of your tire. You could put on E's and run them at 70 PSI for example.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 05-05-2012, 10:05 PM   #3
You would be crazy not to just buy 4 new LT225 R16 tires and be done with the worries of China bomb tires.
Old 05-06-2012, 12:18 PM   #4
I looked at some of the LT tires that people have mentioned (BF Goodrich and Michelin) but I don't have pockets that deep. I'm thinking I can put 3 more goodyears on for $450 and probably be near $600 for a Maxxis set. We do not put many miles on per year as we don't plan on even leaving the state this year. Isn't there something about LT tires not being able to handle the side sliding motion that tandem trailers can exert?
2004 Wildcat 28BH
Old 05-06-2012, 12:30 PM   #5
pbrackney's Avatar
IMHO If you are not pulling your tt full time I would not go with the LT tires. They are not built to withstand the storage time of tires sitting still for storage. That is one big benefit to trailer tires. They are designed for long periods of storage for say "winter time". If you use tt throughout the year then LT tires may be an option.
Philip, DW, 3 DD, 1 DS, and Ginger our Dog
2017 Wildwood 30QBSS
2003 Ford Expedition 5.4 Liter with 3.73 Axle
Equalizer 4-Point Sway 12000# & Tekonsha P3
pbrackney is offline   Reply With Quote
Old 05-06-2012, 03:10 PM   #6
Look at Hankook Dynapro AS LT tires. Cheaper than BFG or Michelin but still a quality LT tire lots of folks are running with excellent results. IMHO if you put Marathon's on you will be paying a lot of money in the future to repair the damage when they explode.
Old 05-06-2012, 03:27 PM   #7
acadianbob's Avatar
Just took off a set of Goodyear Marathons that had 25,000 miles on them. NEVER had a hint of a problem. Only took them off because of age and mileage. They still looked great. Obviously some wear from 25,000 miles. They saw all day tows in 95 degree heat. Scrabbled over rock strewn National Forest Service roads. It's a fine tire.
