Old 04-01-2015, 10:15 PM   #31
ryand's Avatar
Originally Posted by OldCoot View Post
They make good bumpers for a boat dock.
Or a go kart track.
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 04-02-2015, 07:13 AM   #32
dcheatwood's Avatar
Good for burning stumps too.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 04-02-2015, 01:14 PM   #33
No issues so far. Tires are 1 year old Trail Express with about 1500 miles on them last year. Usually run at 65 MPH or less with perhaps 100 miles total between 65 and 75 MPH. Camper stored in our attached garage (stays above freezing, no UV) between trips.
But then we have an A-frame (single axle) which we typically weigh in at about 2600 lbs (3100 lb GVWR). For reasons not totally obvious to me, PUP and A-frame owners do not seem to suffer nearly as much from the "China bomb" syndrome.
Perhaps the single axle isn't nearly as hard on tires, or perhaps the smaller tire sizes have more reserve capacity built-in, or ....(fill in your own theory).
I do a visual inspection of the tires, and inflate to 50-53 PSI (depends on expected temps for trip) before each trip (2-4 days).
just my experiences
Fred W
2014 Rockwood A122
2008 Hyundai Entourage (minivan) w/ Equal-i-zer 600/6000 WDH
Old 04-02-2015, 01:49 PM   #34
Trail Explode tires!
2014 Windjammer 3025W Diamond 34.5 ft 8300 lbs.
2010 F150 SC XLT 4x4 5.4L, 3.55 gears 20" rims
12 k Equalizer WDH, Firestone Airbags, HD Bilsteins
TST 507RV TPMS
Zolin is offline   Reply With Quote
Old 04-27-2015, 11:23 PM   #35
V-Lite Fun's Avatar
I had a Trail Express pop on my V-Lite. I want to upgrade from C load range to D. I was told the rims may not stand the higher pressure. The rims came with the tire and are rated for 2150 lbs. it says nothing about higher pressure. Anyone done this?
Forest River Flagstaff V-Lite 26 WRB. 2015 Ford F 250 diesel, Hensley Arrow Hitch
http://rvadventuresofpetedoll.blogspot.com
V-Lite Fun is offline   Reply With Quote
Old 04-28-2015, 04:16 AM   #36
Witch Doctor's Avatar
Yes I have done that when I switched to a Marathron D rated CP is 65 lbs. that I run them at. Do you have the series 6 rims ? I'll attach the chart from Lionhead. The rims can hold alot more pressure then that. I have not had any problems in the last 2 years knock on wood.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 04-28-2015, 08:17 AM   #37
V-Lite Fun's Avatar
I do have the series 6 rims. Thank you for the chart. This was very helpful. I'm going with Ds. Thanks.
tire, tires
