Old 02-27-2014, 10:29 AM   #1
Any thing positive about Trail Express tires?
My new Windjammer 2618 came with Trail Express ST225/75/15 tires. I've read many comments on this forum about trailer tires and those that mention Trail Express tires are almost all negative. Does anyone "out there" have anything good to say about this brand? For example, have you had no problems with your tires and/or are you getting good milage out of them?
Jack and Laurel
Years married - 46, years camping together - 47
Two 70 lb lapdogs, Ollie and Shadow
TV - 2015 Silverado 2500 HD Allison/Duramax Diesel 4WD
TT - 2014 Rockwood Windjammer 2618
Texbahrs is offline   Reply With Quote
Old 02-27-2014, 10:43 AM   #2
B and B's Avatar
I have towed 2500 miles on them and they still hold nitrogen and have no visible tread separation of other failures. I have had very little 4 lane travel with extended distances. Most 2 lane roads limited to 55 mph. I check them for over heating and do not go over either load rating or speed rating.
I am looking at replacing them this spring, looking at higher load capacity. I did my truck to E range LT tires a month ago.
Brian
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 02-28-2014, 08:10 AM   #3
jonrjen's Avatar
Their cheap to replace with the same tire size and brand...does that help?
You will ready more than enough complaints on these to make you run out and replace them ASAP. But, then keep in mind that the people who are happy with them don't tend to complain.
The secret to any tire is to know their limitations as far as weight and speed limits (most trailer tires are limited to 62mph) keep them inflated to the proper PSI, and inspect them before every trip.
Downside is that even if you purchased your trailer new, you don't know how they were treated upon delivery to your selling dealer from the factory. IE: did the delivery driver keep the trailer under 62mph or speed and allow the tires to over heat. Were the tires under inflated and allowed to over heat or cause excess sidewall flex? The problem with tire inspections is that the damage begins under the exterior rubber compound where is can't be seen. And by the time you can see a bubble or tread separation it is too late to do much about it other than replace the tire and hope you are in an area with a few good tire stores with a selection to choose from.
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 02-28-2014, 10:05 AM   #4
Wanna Be Camper
SaskCampers's Avatar
Well said.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 02-28-2014, 10:30 AM   #5
Perma-Newb
I found this comment interesting. When I first saw my trailer on the lot my first impression of the wheels and tires where negative, I couldn’t believe how beat up they where, they weren’t even the same brand What I later found out is that the shipping company that my dealer used puts “Delivery tires” on the TT then that get swapped for the new shiny wheels and tires upon delivery. I thought that was a good business practice.
2015 F350 Dually, 6.7 PSD
2014 V-Lite 30WIKSS, Diamond Package W/All the goodies
http://www.forestriverforums.com/attachments/signaturepics/sigpic50858_1.gif
EarlyRetirement is offline   Reply With Quote
Old 02-28-2014, 10:41 AM   #6
B and B's Avatar
Sounds either a good dealer or delivery company they have. I believe my dealer makes the trek to Elkhardt to pick up his own units. They have 5 people with trucks that are campers there.
B
Old 02-28-2014, 10:50 AM   #7
ryand's Avatar
The only positive I will say about trail express tires is that they make a fantastic base for a playground all ground up and such. They practically will grind themselves up so the work is minimal to keep little billy from getting a bruise. Although i never had a blowout, the tread loss from just one season was dramatic and they were already starting to crack within 1.5 years of new.
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 02-28-2014, 10:53 AM   #8
jonrjen's Avatar
When our Wildcat arrived one tire held 38PSI and had experienced one blow out during delivery. The tire with low PSI was later found to have been plugged due to a hole and was not a good plug at that.
My local servicing dealer does drive from Texas to Elkhart to take deliver and haul them back themselves. He mentioned that staying within the tire limitations the only time he experiences problems is in the dead of the high temp summer heat that can cause a tire to over heat.
2013 Wildcat 353LS
Old 03-20-2015, 08:26 AM   #9
My new 2014 Windjammer came with these 225 75R15 C range junk tires. The tires were only 3 mos old when the trailer was manufactured so at least the DOT codes were fresh when FR installed them. I put maybe 3 k highway miles on them last year (750 to tow home from purchase) and when I pulled my trailer out of storage this year I noticed small cracks starting to form near the rim on the 2 right tires. It was still 3 mos under warranty so I took to my dealer and they were referred to Lions Head who apparently handles the warranty for Forest River. Lions Head refused to replace them claiming they had either been improperly inflated or over stressed. I called Lions Head back and told them I had documentation showing 6 separate weighs of this trailer, inflation was always held at 50 psi and always stored in enclosed storage to avoid sun damage to the coach. I told her I would take my matter further if they still refused to replace them and that these tires were defective. I drive 58-62 mph for best fuel economy and safe control so the tires were never stressed this way or even driven in hot temps because we are spring/fall campers. She told me she would talk to her manager and then get back with me. Better news, I received calls from both Lion's Head and from FR Rockwood warranty and they said they would replace the 2 defective tires so they shipped the next day. Not received yet but at least FR stood behind their warranty. I had a few other unrelated minor issues which FR also took care of through the dealer. Other than that we love our Windjammer and FR has delivered on their warranty policy. Still don't like the junk tires and after learning all this through research I will eventually replace them with D or E range Tow Master radials from Costco. The C range tires are just insufficient unless you plan to park in a seasonal or permanent location and not do much driving like we do.
Zolin is offline   Reply With Quote
Old 03-20-2015, 10:07 AM   #10
Road-King's Avatar
Something positive... Hummm.. After I replaced them on my TT, I had them installed on my flat bed utility trailer and they are doing good around town hauling mulch etc...
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
tire, tires
