Jer, I have the same MH as you from the 2013 model year. When first delivered I felt like the steering was so bad and my control so comprised that it was unsafe. The first thing I did was add a rear steering control, helped a little, had the front end aligned to the specs posted on both the Forester and Sunseeker threads, steering improved dramatically but passing trucks, buses etc still moved me around the last thing I added was the Safe-T-Steer - problem solved. RV is like driving my RAM pick-up. Solid control, minimum movement caused by passing trucks able to feel comfortable in all driving conditions. I hope this helps.
