Old 04-18-2015, 07:50 PM   #1
Anyone know what this is
Crawling under my coach looking for a good way to run data cable for my progressive industries surge protector I saw this. Looks like a vacuum line. Has what looks like 2 spots that mice have chewed.
ID:	74640   Click image for larger version
2011 Georgetown 337 2011 Chevy Impala
pakkdad is offline   Reply With Quote
Old 04-18-2015, 07:53 PM   #2
fonzie's Avatar
BU94-9C985-BA by FORD - TANK,EVAPORATIVE SYSTEM VAPOR
Fonzie
Old 04-18-2015, 07:56 PM   #3
Old 04-18-2015, 08:01 PM   #4
Surprised you don't have a check engine light on.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 04-18-2015, 08:03 PM   #5
No lights on. Drove it home from dealership a week ago. Set it up in drive
Old 04-19-2015, 02:56 PM   #6
Does the check engine light come on when you 1st turn the ignition switch on?
mike.t is offline   Reply With Quote
Old 04-19-2015, 03:10 PM   #7
No check engine light.......Yet. PCM needs to run 2 drive cycles to set the light
Billandpam is offline   Reply With Quote
Old 04-19-2015, 04:22 PM   #8
Not sure about the light at the moment. Set up in the driveway, slides out, levelers down. Can't start at this time. Going to move shortly.
Old 04-19-2015, 04:36 PM   #9
The "2 drive cycles" is to reset the system IF the check engine light came on and a repair was done. I believe.
Old 04-19-2015, 05:34 PM   #10
Dodge Guy's Avatar
As was stated, that is a charcoal canister for the emissions. It may not set the light, due to the GVWR. Even though it has an OBDII connector the software in the PCM is running OBDI programming. Replace the chewed line and you will be good to go!
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 04-19-2015, 06:03 PM   #11
toslow's Avatar
that line looks like it's for more of a moisture release
haven a blast
toslow is offline   Reply With Quote
Old 04-19-2015, 06:06 PM   #12
Just moved coach to its summer time waiting for camping spot. No dash lights stay on. Off to Ford garage tomorrow. Thanks for all the replies.
Old 04-27-2015, 11:53 PM   #13
27 dollars and 5min later new one installed
ID:	75459   Click image for larger version
