Old 02-27-2015, 06:49 PM   #21
Commercial Member
Originally Posted by Vallgrlx2 View Post
We recently purchased a Coachmen Catalina 243 RBS. The PDI went went smooth. Only 1-2 minor items to correct. However, after reading the FR forums, it appears the FR installs China Bomb tires on all units. If so, how do I identify a China Bomb tire, and what recourse do we have with the dealer or FR?
Ford 150 Eco Boost
2016 Coachmen Catalina 243 Banner Edition
Ford 150 Eco Boost
If you read the tire sidewall you will find a "Made in xxxx" statement.
You can also use THIS web site and the first two characters of the DOT serial to learn the actual plant where your tires were made.
If you review my RV tire blog, you should find answers to almost every question you have on tires and the proper application on Rv service.
If that isn't enough you can send me email (address posted under my picture on my blog) and I will answer your specific question other thaan to make recommendations on what tire to use.
I even have ten posts that mention China made tires.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 02-27-2015, 06:55 PM   #22
Carknocker Family
Ida Ratherbe Camping's Avatar
Like them or don't, I just purchased a set of Gladiator ST225/75r15. 10 ply.. What I read, on reviews was good, so I went for it. A feller at work has a set of gladiator mud tires on his Chevy and had nothing but good things to say about them. No matter what, I feel that they will be better than the Lions head 8 ply that they are replacing. I will let y'all know.
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 02-27-2015, 08:12 PM   #23
My last two fivers had tires made in China as standard and on both I told the dealer if he wanted the sale the tires had to be made in America. With you already buying the unit it may be a tough sale to get them replaced, if you can afford it I would change them out for piece of mind.
Pitcrew18 is offline   Reply With Quote
Old 02-27-2015, 08:58 PM   #24
Salt Shaker's Avatar
There is zero nada none zilch incentive for FR to upgrade tires...Tire goes boom... Trailer goes boom...daddy buys a new 5er. The trailer tire wells on these rolling wonders are junk design. Add a metal box around the area with tires to protect everything. If passenger and LT tires blew at the rate of trailer tires the roads would be a mess.
I tow trailers all the time. Two boats and one is always hooked up. Kept undercover and maintained I am good for at least one blow out a rear on one of my trailers...sometimes two.
I am of the opinion the only thing to do is swap them all every 2 or 3 years.
My 2 cents
Salt
2014 Silverback 29RE, 2014 Ram 2500 CC 4x4 Hemi 6.4 auto w/ airbags, B&W Companion. Saltwater boats and rum like any good pirate.
Lose the 2nd and the rest will follow.
Salt Shaker is offline   Reply With Quote
Old 02-28-2015, 08:29 AM   #25
Lt's Vs St's
Everybody has an opinion on tires. You just have to go with your gut. I have been pulling 5th wheels since the 70ís and am always anal about the tire pressures and still have had a few blowouts. Be careful putting LTís on a trailer. You can pull the sidewalls loose on LTís if you get in a bind and have to make some sharp maneuvers while backing. It is a sure disaster and the tire will eventually fail. This can happen on STís as well but they have a little more flexibility in the sidewalls
fasthauler is offline   Reply With Quote
Old 02-28-2015, 08:59 AM   #26
B and B's Avatar
Originally Posted by elind View Post
I believe that how these tires are used leads to trouble more than who made the tires. Just because they were made in China doesn't make them all equal. The same is how they are used on different RVs. Take a load range C tire on an average RV and the max load is 1,000 over dry weight. Add 1,800 pounds of cargo into it with something too heavy in the front or back. Now hookup your RV to your TV only to find out the hitch height was a little off and one set of axles is carrying too much weight. Oh yah, the tire pressure wasn't up to the max inflation. Oh well, time to head down the road and your doing 70-80 mph all day. When bam, the China bomb blew up!! What is the first thing to blame? Maybe all of the above. But a start to the problem would be upgrade to a load range D or E tire. Then figure out the rest.
I agree 100%. All tires can fail. The stock ones I replaced had a bead issues with crumbling, more so to do with install than actual manufacture. I had a lift kit put on my trailer due to what blind said about towing level and equal loads.
P Pressure
L Loading
S Speed
If all the above are within spec you are running safer.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
tire, tires
