Old 12-08-2018, 04:45 PM   #1
Senior Member - Retired
Attempting To Calculate "Real World" max total loaded weight for my Georgetown
I am confused (not that rare a condition for me) trying to figure out the maximum load my motorhome 2014 Georgetown XL 334QS can handle. Ratings are as follows
GVWR 24,000 lbs.
GCWR 30,000 lbs.
GAWR Front 9,000 lbs.
GAWR Rear 15,500 lbs.
Tires are Michelin XRV 255/80R22.5 LR=G, currently inflated to 100 psi
Appears to me the maximum weight for single tire (@110 psi) is 2,360 lbs., and the maximum weight for tire (@110 psi) in dual configuration is 2,180 lbs.
If the above weight ratings are correct it would seem:
Maximum usable load for the front axle is 4,720 lbs., not the rated 9,000
Maximum usable load for rear axle is 8,720 lbs., not the rated 15,500
This then equates to usable GVWR of 13,440 lbs., not the rated 24,000
Hopefully I am somehow calculating incorrectly. Any comments, input, clarification, suggestions, will be most welcome.
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
CA Fisherman is offline   Reply With Quote
Old 12-08-2018, 04:52 PM   #2
GVWR 24,000 lbs.
GCWR 30,000 lbs.
If you have G load rated tires it should be closer to 4400 lbs at 110psi
2360 is closer to an e rated tire
MR.M is offline   Reply With Quote
Old 12-08-2018, 05:21 PM   #3
Mr. M. You sir are correct. Your response prompted me to take a second look at the tire sidewalls. It is embarrassing to admit that I had recorded the kg not lb weight rating. The ratings I should have used are 5,206 lbs. for single tire and 4806 lbs. for tires in a dual configuration. This equates to revised tire based front axle load of 10,412 lbs. and real axle load of 19,220 lbs. Now I will play a bit with load ratings at a lower psi (100) to see if I can help soften the ride. Again, thank you for taking the time to respond and for your eagle eyes!
2013 Smart Car TOAD
Old 12-08-2018, 06:49 PM   #4
No problem , glad i got one right lol
Old 12-08-2018, 07:53 PM   #5
Tire ratings are always the controlling factor regardless of the axle weigh rating. Ideally you'd always have a higher rated axle than the rating of the tires.
This would keep axles from bending when going over bumps. Better to sacrifice a tire than bend an axle.
Then just keep load beneath tire rating.
Remember the saying: "Why is it that people take up RV'ing to get away from it all then try to take it all with them"?
I have it on my dog's authority that an afternoon nap is acceptable.
Politically Incorrect since 1943
2004 Nissan Titan
Old 12-09-2018, 02:02 PM   #6
Dahagen
In a couple of places on your RV you should find a yellow label listing weight info, including CCCC.
dahagen is offline   Reply With Quote
Old 12-09-2018, 02:11 PM   #7
So far I have found GCWR, GVWR and GAWR for each axle. My weight distribution is not too bad, however I am going to try and move about 1,000 lbs. of load from the rear axle towards the front of the motorhome, for improved weight distribution and possibly lower tire pressures to improve ride.
I have individual scale weights for each tire position so have data to work with.
2013 Smart Car TOAD
Old 12-09-2018, 03:04 PM   #8
Weight Question
For CAFisherman, I read your post on Weight distributions. I have a 2015 Georgetown 352XL with 4 slides also. Two questions come to mind. Are you having trouble with driving as to your weight distribution? Did you try the CHF on your unit. Mine drove me nuts driving before doing the CHF. (Cheap Handling Fix). I truly never felt any difference driving with regard to different tire pressures. (95 thru 105).
weatherguru1 is online now   Reply With Quote
Old 12-10-2018, 02:36 PM   #9
Yes, I performed the CHF early on, then added a steering stabilizer. Recently I added SUMO's on the front axle resulting in a noticeable improvement. Knowing our MH is heavier in the rear and lighter in the front than I would like I added SUMO's to the rear axle. Now over all handling is much improved including wind sway from passing semi's and lane position stability. The negative of the SUMO's was a harder ride in the vicinity of the rear axle. I slightly dropped the air pressure on the rear axle dual tires and the ride improved. Now I am working to determine the most appropriate pressure for tires at all four positions.
2013 Smart Car TOAD
Old 12-11-2018, 01:45 AM   #10
GVWR 24,000 lbs.
GCWR 30,000 lbs.
110lbs seems fairly high. Have you got a sticker somewhere in the unit that tells you what to inflate tires to? 110 lbs is probably the tire rating for max load for the tire. You may not even be near max for the tire rating as you are restricted to the GAWR. I would suggest 110 PSI would be for a much larger vehicle ie: higher axle ratings, larger spring packs such as in small semi trailer, large delivery truck. My motorhome states 82 PSI for 19.5 tires but the tire rating is much higher. See you got the KGs and LBs figured out.
2017 FR3 28 DS
cariboo camper is offline   Reply With Quote
georgetown, weight
