Old 09-28-2015, 01:47 AM   #11
Just a member
kandl's Avatar
Originally Posted by gljurczyk View Post
Not sure what axles you have but if you have AL-KO there is a company that still sells Al-KO and the bearings...
AL-KO did not make their own bearings either. Filterman and Ford Idaho have alluded to this. The bearings installed in AL-KO axles, like others, are widely available at NAPA or numerous other part sources. You need only to read off the number on the bearing races.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 09-28-2015, 01:56 AM   #12
Just a member
kandl's Avatar
Originally Posted by purvis View Post
I get a call from the service provider that I need to replace both axles because there are no bearing replacements according to the axle manufacturer.
I don't believe that for a senior's moment - the service provider is pulling the wool down.
Btw... welcome to the forum!
Old 09-28-2015, 03:57 AM   #13
Witch Doctor's Avatar
This is true Kandl, But I always find it easier to just give the axle # to the manufacture and buy the parts there. I think I paid 46.00 for 4 sets with shipping. But that is just me. His trailer is only 5 years old and from his description it sounded like AL-KO to me. As far as I know FR only uses Dexter or al-ko which dexter did by out but Al-Ko still has a separate division. Napa would be my second choice.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 09-28-2015, 04:35 AM   #14
Just a member
kandl's Avatar
Roger that. Don't have that luxury in these parts unless we want to wait weeks and weeks on end for parts. Known for a long time that utility trailers and towable RV's employ standardized bearings. What surprised me a couple of years back, when replacing an outer bearing on one of our AL-KO U40 (4000 lb) axles, is that the bearings are identical to the U35 (3500 lb) axle bearings. WTH? How can bearings spec'd for a 3500 lb axle be acceptable for a 4000 lb axle? If this seems reminiscent to a common weight related refrain, then you know the answer.
Old 09-28-2015, 06:32 AM   #15
TURBS's Avatar
I am a subscriber to napa pro-link.
Get me a number and I'll get you numbers you can order.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
Old 09-28-2015, 09:04 AM   #16
jimmymjr's Avatar
Parts manufacturing is a small community. It is common for one manufacturer to make parts for several brands. there is someone out there that will have a replacement. I have better luck at small mom and pop auto parts stores than big box stores because the people that run them have more knowledgeable staff. Big box stores hire people that have never worked on a vehicle much less know what you are talking about searching for a non car related part.
jimmymjr is offline   Reply With Quote
Old 09-28-2015, 04:20 PM   #17
A32Deuce's Avatar
There are places that only deal in bearings of all types. You can find them on the internet. You can give them numbers from the bearings you have or give them accurate measurements and they can find what you need. Did that one time for a bearing the parts store couldn't locate. (Real parts store with books!)
A32Deuce is offline   Reply With Quote
Old 09-28-2015, 04:28 PM   #18
Georgia Frog Rally 2018
aceinspp's Avatar
As long as you have part num you can find. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 09-28-2015, 05:16 PM   #19
A32Deuce's Avatar
I got a bearing with just the proper measurements, was a machinist by trade. I didn't go to a parts store. Bearing supply.
Old 09-30-2015, 03:14 PM   #20
Lippert problems
Found bearings took them to Camping World last week, today get a call that hubs are bad too, From: Dan Collins [mailto:dcollins@lci1.com]
Sent: Tuesday, September 22, 2015 8:00 AM
To: purvis@heartofiowa.net
Subject: FW: Wheel Bearings
Sir,
We are not able to get any parts for the SBS axles any longer like the ones you have on your unit. If you are needing to replace any parts such as the hub or bearings then you will need to purchase new hubs and possibly new axle beams. You will be able to use the existing brakes and springs from your current axles. Please contact our parts department if you should have any further questions. Thanks,
purvis is offline   Reply With Quote
axle, bearings
