Originally Posted by LorenzoP
Thanks for replies everyone. I’m currently in Nebraska (staying sober) on way home. After inspecting that visible disk - it’s made of rubber and loose. Wheel seems to operating normally. Btw home is Wisconsin another 700 miles or so
I think others will agree, removing the brake drum to see what's going on is highly recommended. If the bearings is damaged, you could end up with a disaster to deal with and you sure don't want that happening in the middle of nowhere. I wouldn't go another mile if it were me. At the very least, as suggested, jack the wheel up and see if it wiggles at all. A loose wheel bearing can even destroy the tread on a tire in no time, depending on how loose.
The grease cap is metal and has a rubber plug on the end that you remove for access to the grease nipple on the end of the axle. You're seeing the rubber plug but in the photo looks to me like the whole grease cap has come out.
Removing a brake drum is easy. Pull the cotter pin out of the castle nut and undo the nut. To put the nut back on, tighten it, back it off, tighten it again hand tight, then back it off the least amount needed to get the cotter pin into the hole in the axle (and bend the ends back). If you have no tools and a hardware store is close by, get a crescent wrench, needle nose pliers and a flat blade screwdriver.
