Old 10-26-2012, 06:57 AM   #21
Herk7769's Avatar
Originally Posted by gljurczyk View Post
Do not use lithium.
This has to be a typo.
The correct lube for Ultra Lube axles is Number 2 Lithium Complex of any color provided the drop point exceeds 230 C or 446 F (the temperature where the lube becomes liquid instead of semi-solid).
See attachment for Lippert Flyer and associated WARNINGS regarding any other type grease.
File Type: pdf 0132-bearing-inspection-maintenance.pdf (112.1 KB, 69 views)
HAM CALLSIGN - KC3FFW
Old 03-31-2013, 06:07 PM   #22
moondog2000's Avatar
Last month I finally did my bearings. I used Lucas xtra grease and what I did was jack each tire up and spin it while ai pumped the grease in . I did this till i was wiping clean grease out of the cap. I understand this setup. This is just like packing the bearings. I figure once a year I will repeat this having fresh grease in both bearings. I also took the time to check all bolts on the running gear. Good thing I did as I found on brake backing plate bolts loose, also the cotter pin on the same axle not placed well. Thank you everyone for you replies as I want to keep my trailer in tip top shape. Happy Easter, Mike
moondog2000 is offline   Reply With Quote
axle
