Old 10-25-2012, 01:03 AM   #1
moondog2000's Avatar
Axle grease
I just bought a Forest River 2013 X-Lite and it has the Ultra Lube axles and I was wondering what grease comes packed in the bearings from the factory. I want to pump some grease in some time but I don't like mixing grease. The salesman said it was napa lithium wheel bearing grease but I need to know for sure as I drive the desert in tripple digit weather.I sure don't feel like packing the bearings of a brand new trailer.I want to enjoy it for a while. Looking at another post it looks like when you pump the grease in it goes to the back of the hub or rear bearing and works its way forward and comes out up front some how? how do you get the old grease out? Is it easy and I'm asking a stupid question? Thank You Mike
moondog2000 is offline   Reply With Quote
Old 10-25-2012, 03:42 AM   #2
Witch Doctor's Avatar
Your ultra lube axles are very handy. You need to meet the Mauf. specks of the grease. Napa sells a tractor bearing lube which is rated for 500 degrees it comes in a green tube, they also have a red tube that is rated at 550 degrees. Both meet the specks that are recommended. Do not use lithium. As you pump the new grease in the old will be pushed out and collected around the zerk fitting area and then just wipe it out. becareful the edges are a little sharp and can cut your finger. I had to replace 3 zerk fittings being they would not accept grease got them at napa. Just as a note my TT came about a tube and a half low. Think of the unit as U shaped with a channel going down the center. You do not have to pull the bearings out to repack. Now with that said you should inspect your bearing depending on your usage. If you pull the bearing you will need to get new seals after inspection. It is a pretty easy system but make sure to check your grease levels by adding grease now and then and you will be a happy camper....
Old 10-25-2012, 07:41 AM   #3
MtnGuy's Avatar
Originally Posted by gljurczyk View Post
Do not use lithium.
Huh ?? I believe Dexter, Lippert, and Al-Ko all recommend using lithium based complex grease.
Old 10-25-2012, 08:24 AM   #4
Iggy's Avatar
X2
Use the highest temp and don't over grease.
Don't over grease. Just 2 pumps per 500 miles.
Old 10-25-2012, 09:35 AM   #5
mtnguy you are correct. The manual reads "the soap type should be lithium complex or equivalent the specs which are important are USE NLG1 grade 2 with a min. drop point of 440 degrees" I do not use lithium grease except on my boat trailer, being I hope I never back my 5th in the water. I guess I'm just a farmer at heart...
Old 10-25-2012, 09:39 AM   #6
w4drr's Avatar
Here is a copy/paste from the AL-KO manual:
"Use a high temperature, automotive type wheel bearing grease
produced by a reputable manufacturer. The soap type should be lithium
complex or equivalent. Use NLGI Grade 2 product
with a minimum dropping point of 440
F."
Bob
Bob & Doris
Roanoke, VA
2009 Toyota Tundra CrewMax 4x4 - 5.7L - 6 Speed Auto - 4.30:1
2013 Rockwood HW296
w4drr is offline   Reply With Quote
Old 10-25-2012, 09:54 AM   #7
I think the OP was concerned with matching the existing grease ("...I don't like mixing grease..."). Maybe a call to the axle manufacturer -- or FR -- is in order?
"But, oh that magic feeling, nowhere to go." -- The Beatles
2015 Flagstaff 8528RKWS fiver
2013 Ram 2500 CTD Laramie CC SB 4WD Auto
cbconway is offline   Reply With Quote
Old 10-25-2012, 10:11 AM   #8
I think as long as you use grease that meet the requirements that w4drr posted you won't have problems.
Len & Cheri is offline   Reply With Quote
Old 10-25-2012, 10:30 AM   #9
acadianbob's Avatar
I didn't worry about matching. I just bought NAPA's best wheel bearing grease and pumped it in. 25,000 miles later, all is going fine.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 10-25-2012, 11:27 AM   #10
One of the requirements in the specs on grease and oil is it must be compatible with others having the same specs. Don't worry about mixing like kinds of grease or oil. The military does not use a specific brand on a specific vehicle. That's why the oils & greases are compatible.
axle
