Old 08-29-2016, 04:00 PM   #1
jonrjen's Avatar
Axle Grease...what do I use?
I know, it's a stupid question. But, I'm man enough to ask it anyway. Getting ready to hit the road with our 2013 Wildcat and thought I would add some grease to the axles.
What do I use the choices out there are staggering, but what is the appropriate grease?
2018 Berkshire XL 40B
Past RVs: National Pacifica 40', Kenworth T300 Toterhome, Jayco Class C 32'. American Eagle 40',
American Eagle 40', Bounder 38' tag axle
jonrjen is offline   Reply With Quote
Old 08-29-2016, 04:06 PM   #2
the link below is what I just used, I like the full synthetic stuff.....
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
fella10 is offline   Reply With Quote
Old 08-29-2016, 04:16 PM   #3
Lucas Red "N" Tacky at your local parts store.
Old 08-29-2016, 06:20 PM   #4
SilhouettePenny's Avatar
NLGI Grade 2 at Walmart, they also carry Lucas Red & Tacky.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 08-29-2016, 06:28 PM   #5
trbomax's Avatar
In the "lippert axel,wheel bearings" section of your owners manual it lists the various compatible greases.Mine is out in the trailer or I would post them up.
trbomax is offline   Reply With Quote
Old 08-29-2016, 09:17 PM   #6
jonrjen's Avatar
Thanks for the help and assistance folks, much appreciated!!
I will be heading down to Lowes tomorrow to pick up some lumber to make a ramp for pulling one wheel up on and leave the other tire and wheel hanging so that I can turn the wheel while pumping in the grease.
Thanks again,
Jon
Old 08-29-2016, 09:36 PM   #7
I've got a tube of this stuff. Is it good for bearings on a boat trailer too?
Sent from my SM-T320 using Tapatalk
2016 Salem Cruise Lite 261bhxl
Ram 1500 5.7l Hemi Crew Cab 4wd
gspot01 is offline   Reply With Quote
Old 08-29-2016, 11:55 PM   #8
Brush's Avatar
Walmart sells the Lucas Red "N" Tacky for $4.98 a tube in my area.
Bill and Darlene
2008 Tundra 5.7, 4.30 axle, 8' Bed, 4WD, Super Springs
2021 Flagstaff 832RKSB as of Aug 2020
Nights camped in 2021 Flagstaff: 2021(151) 2020(109)
Nights camped in 2009 Rockwood: 2019(62) 2018(33) 2017(25) 2016(31) 2015(34) 2014(37) 2013(36) 2012(37) 2011(21) 2010(48) 2009(33) 2008(18).
Brush is offline   Reply With Quote
Old 08-30-2016, 12:34 AM   #9
Witch Doctor's Avatar
I use Lucas Red and also Green tacky. The drop point is like 460 degrees, one of the highest on the market. If you have the hubs that you fill with a zerk fitting you can change the color of the grease to make sure you get all the old out and new in. Found the green at the local Napa store...
Coachmen M/H
Concord
2018 / 300 DSC
Old 08-30-2016, 07:08 AM   #10
f5moab's Avatar
I use Mobile 1 synthetic grease.
Drop point is 550 degrees.
Lithium complex.
NLGI No 2
It is NOT cheap!
f5moab is offline   Reply With Quote
Old 08-30-2016, 07:25 AM   #11
X2
Trevor43 is offline   Reply With Quote
Old 08-30-2016, 03:37 PM   #12
2003 Georgetown 325
Whatever you use make sure it is compatible with whatever is there now or the grease will turn to liquid and run away. If you don't know then take the wheel off, clean off the grease from the spindle and bearings and repack with whatever you are going to use. Not all greases like each other
reddiver is offline   Reply With Quote
Old 08-30-2016, 07:21 PM   #13
lugoismad's Avatar
Lucas Red N' Tacky. Just filled up all 4 bearing buddies with it last week.
lugoismad is offline   Reply With Quote
Old 08-30-2016, 09:08 PM   #14
Ret E-9 Anchor-clanker
donanddona's Avatar
I focus on high temp/pressure. Don't need water resistant as I'm not launching a boat. Also I switch colors as to easier notice when I've gotten that good flush of the hub. I use a lot of grease usually two to three tubes totally for four hubs. Do it on a nice hot day to help maintain that inner hub seal. Attachments show a healthy and an unhealthy bearing. The unhealthy bearing did get replaced after finding shavings in what poured out.
ID:	118924   Click image for larger version
donanddona is offline   Reply With Quote
Old 08-30-2016, 11:37 PM   #15
moondog2000's Avatar
Lucas Red N Tacky is a lithium base grease and lucas Green N tacky has a polyurea base and you do not want to mix them according to the e-mail lucas sent me. I use red n tacky and it works well in everything I own.
05 Silverado Z71 4X4
2013 Forest River X-LITE
Days camped in 2018, 27
moondog2000 is offline   Reply With Quote
Old 08-31-2016, 01:50 AM   #16
2007 WildCat 32QBBS
18CrewDually's Avatar
Out of all the responses this is the most important. Like stated, if you don't know, start fresh. I too use the Lucas Red "n" Tacky in all my trailers. It's never a guessing game.
At the same time I recommend to replace the seals with a double lip seal if it doesn't have them already.
18CrewDually is offline   Reply With Quote
Old 08-31-2016, 06:13 AM   #17
Gosh-dern! Really! Now im gonna have to repack the bearings on my boat trailer
Never done it before and have been mixing greases right and left. Let me put it on the to-do list and Google how it's done!
Old 08-31-2016, 07:00 AM   #18
2007 WildCat 32QBBS
If it's compatible don't sweat it. On a boat trailer your constantly pumping grease through the hubs anyways. For boat trailer I use a synthetic marine grade grease. It doesn't mix with moisture at all compared to a standard automotive grease.
Old 08-31-2016, 07:08 AM   #19
f5moab's Avatar
Compatibility charts are abundant...
Old 08-31-2016, 09:57 AM   #20
NorSnrub's Avatar
If you are useing zirk, don't pump gun more than 2 or 3 times to prevent grease blow out. It is best to repack by hand.
NorSnrub is offline   Reply With Quote
axle
