Old 09-03-2014, 01:50 PM   #71
TURBS's Avatar
Glenn thanks for tak I ng the heat off me lately!
TURBS
"SABRE OWNERS UNITED"
Old 09-03-2014, 07:09 PM   #72
gooiebob's Avatar
gljurczyk,
Your patience is commendable. How's your blood pressure?
2013 Rockwood Ultra Lite 2703ws
2014 Toyota Tundra 5.7
gooiebob is offline   Reply With Quote
Old 09-03-2014, 07:39 PM   #73
2007 WildCat 32QBBS
05CrewDually's Avatar
Hug it out guys, hug it out.
If it was me, I'd weld a few beads so they can't move.
05CrewDually is offline   Reply With Quote
Old 09-03-2014, 07:44 PM   #74
Bolts are easily removed in case the axles need replacing. But a tack weld would also work.
Old 09-04-2014, 02:48 AM   #75
Witch Doctor's Avatar
That's exactly what they did on mine might be hard to see in the pictures. I just can't see it moving up with the weight of the trailer on it. The bolts are at the bottom of the slot now how can it drop is beyond me....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 09-04-2014, 06:38 AM   #76
PhoneDude 8289's Avatar
It is still not clear to me how the RV / axels could open that gap but at some point the axels dropped and the gap opened up. From the marks on the brackets it happened more than once. I also don't know why they didn't close up once the weight was back on the axels. Could be the horizontal bracket bolts were not tight enough but then you would think they would close when the weight was back on the axels. I torqued them to 180 ' #. The bolt chart called for 212 ' # but 180 was all this old man could do laying on his back. I feel good about bolting the brackets, they are solid and safe.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 09-04-2014, 06:52 AM   #77
Torsion axles by design want to rotate to relieve the torsion imposed by the rubber/neoprene cords. That's what causes them to rotate on the front of the support only. It is the same principle as the torsion spring on the lh end of the awnings.
Name:	Torque on torsion axles (2).jpg
Old 09-04-2014, 08:32 AM   #78
Thanks O.C
Joe & Beverly
2014 8289WS lifted
mount, axle
