Old 03-01-2012, 09:00 PM   #1
axle replacement costs and needs
Well we decided not to by a new TT and are going to make the repairs to our 2000 Flagstaff 829BHS
main repair is the replacement of the 2 axles....
One is bent and figured I would have both replaced.
Also only 1 wheel seems to lock up when I brake...(tried on a gravel rd and when I braked hard only one wheel locked up...the other 3 kept a'rollin')
So... does any one know the cost of replacing the axles...?
Does the axle come with new brakes and wheel hub? (ideal)
Closest flagstaff dealer to me is FunTimes RV Center in Antioch, Il 45min away
I dont want to drag TT around trying to get quotes....
braddaddy is offline   Reply With Quote
Old 03-01-2012, 09:13 PM   #2
Also...(sorry).... Can I get quotes for the axle replacement without bringing the TT into the dealer?
And I want to get the 6K axles.... (dry weight is 4600#) Axle bent due to blowout (says previous owner) So I thought 6k axle would rid me of that happening again... I read on here I think that the TT usually come with low grade axles. T/F?
Old 03-01-2012, 09:20 PM   #3
b1b1das's Avatar
While I am not sure of the pricing in your area, I recently replaced the axles on my 20' utility trailer and added brakes. I did the work myself, so I only know what the material cost was. I installed 2 @ 5200# axles, new steel rims with tires. Only the back axle had the brakes though. I spent in the neighborhood of $1100 for the materials for the rims and axles including leaf springs and brakes, the tires were an additional $550.
Hope this helps...
2012 Stealth RG3210
2011 Dodge Ram 2500 Mega Cab Laramie 4x4
2010 Ford F150 Super Crew Lariat 4x4
b1b1das is offline   Reply With Quote
Old 03-01-2012, 10:26 PM   #4
caper's Avatar
In Canada a 6000# axle with break assembly cost $599.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-02-2012, 08:58 AM   #5
You want 4500 pound axles. Times 2 of them gives you 9000 pounds of trailer weight, more than enough. Also, your wheels and hubs may not work on a 6000 pound axles. If you insist, check the spindle diameter of both, to make sure you have enough parts for the job. Most axles don't have the brakes, have to use the ones you have. It will give you a chance to inspect and adjust them. The axles I have replaced as a tech, have come with new grease seals for the hubs. Also came with now U bolts and hardware for mounting. You will need to know if the axles are below the spring, or above. Should be able to get quotes without having to drag the camper around. Good Luck.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 03-02-2012, 10:17 AM   #6
try these guys, I have ordered a few axles and some brake kits from these guys
Southwest Wheel Company Steel and Aluminum Truck Wheels
2007 Cardinal 362bhle 5er
2006 f350 Diesel CC LB 4x4 4.10 locker lariat
1966 Mustang coupe...under construction
2004 Explorer 4.6 awd (16 year old daughters car)
2009 Mazda 6 (wife's ride)
Bunkfamily is offline   Reply With Quote
Old 03-03-2012, 07:46 PM   #7
YIKES.... to replace my axles, general RV wants approx $900 per axle !
I think I might do it myself. I am pretty mechanical. On my truck I have replaced my brakes, rotors, calipers, ball joints, inner/outer rods, alternator, as well as other items on other vehicals.... I should be able to replace the axles...I just didnt 'want' to... but to save $1K +..... I do want to now.
Brad & Melissa
2002 Ford Expedition 4X4 4.6 ltr
1999 ForestRiver Flagstaff 829BHS
Old 03-04-2012, 09:25 PM   #8
jonnys_walkers's Avatar
Determine which axles are under the unit. Check on the websites for your configuration. If there are no other issues of bent components, then order them up, do the wiring and you should be good to go.
Here is an example of the Dexter Axles: http://dexteraxle.com/i/u/6149609/f/..._Lbs_12-10.pdf
Never enough camping!!
jonnys_walkers is offline   Reply With Quote
Old 03-05-2012, 06:51 PM   #9
Thanks!
This is what I have now that I will be replacing....
Mfr. Model Capacity (kg) Size (mm) Static Loaded Radius (mm)
Al-Ko U296 1364/3000 10 x 2-1/4 12.45/316
So on with the hunt for new ones.....
Brad & Melissa
Old 03-05-2012, 06:55 PM   #10
TURBS's Avatar
Id buy from a company such as Midwest Wheel Companies - Home
axle
