Old 11-01-2012, 09:36 AM   #1
camper1999's Avatar
Axle Shackles
Check those axles especially the shackles. I have talked to a lot of people about inspecting their axles and a lot do not. I was guilty of that myself until one day I looked at my shackle straps. They were almost totally worn through which is scary to think about what might have happened if one broke. It only took me 2 hours to replace them and only $30 dollars worth parts.
Old 11-03-2012, 05:54 PM   #2
Oklahoma Proud
MillerTime's Avatar
And if the shackles are wore the bolts probably are too. The equilizer bushing and bolt should also be checked for play.
Old 12-27-2012, 09:46 AM   #3
Dallas Texas
TexasBBQ's Avatar
Ur right, we should check them yearly. I do this after dewinterizing. Last year I put in wet bolts which helps reduce with the bushing wear and noise
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
axle
