The hub, if original, should have the name on them. All my hub drums are stamped Dexter. EZ lube is Dexters name for it, but Lippert has the same system to pump new grease in. FWIW, if you are looking to lube the hubs, I would pull them all and clean/ inspect/ pack if you have never done so. First time I did so on my trailer I found a galled bearing. Less than 3000 miles.
