Old 04-08-2016, 10:38 AM   #1
strat56's Avatar
Axles Shifted?
I have a 2015 Windjammer 3008W I bought in February of 2015 and it looks to me like the position of the axles have shifted. I've attached a couple pictures, one of the driver's side and one of the passenger's side. It seems to be very apparent on the driver's side, not so much on the passenger side but they look a little off center too.
Late last season the trailer started handling differently while towing, it was not as stable as it had been. I tried everything I could think of to fix the towing problem but was unable to resolve it before the end of the season and I had to put it away for the winter.
Anyway here are the pics, any advice or input on how to correct the problem is appreciated.
This is the driver's side, looks like they are shifted forward.
This is the passenger's side, looks like they are shifted back, not as far as the driver's side has shifted forward but not centered either.
Jack and Jan
Nights camped 2014 - 8 | Nights camped 2015 - 23 | Nights camped 2016 - 24
2015 Ford Super Duty F350 > Blue Ox Swaypro WD Hitch > 2015 Rockwood Windjammer 3008W
strat56 is offline   Reply With Quote
Old 04-08-2016, 10:45 AM   #2
Pickin' & Campin'
Torsion axles or springs?
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 04-08-2016, 10:56 AM   #3
TA Youroo!!
Old 04-08-2016, 11:03 AM   #4
Movement should show on/at the "mounting plates that are welded to your axles" they are Bolted to the frame lift spacers! Crawl under and have a look/see! Youroo!!
Old 04-08-2016, 11:14 AM   #5
strat56's Avatar
Dexter Torflex torsion axles.
Jack and Jan
Old 04-08-2016, 11:18 AM   #6
For those axles to have moved as much as those pictures show they would have sheared the bolts and be falling off. By the pictures it looks to be at least 6" total if not more. The rear end of the trailer would be on the shoulder of the road. Maybe the fender skirts were always offset like that since the day it was built and the axles haven't moved? Could you of just never noticed it?
Need to measure back the main rail on each side to a common point on both sides at the axle to know for sure. I would not put it past them to have cut the wheel clearance in the wrong location and then slid one of the skirts forward or back to cover it. Take a tape measure first and measure from the rear corner to the skirts.
Mr Havercamp is offline   Reply With Quote
Old 04-08-2016, 12:38 PM   #7
Our fenders are not centered on the wheels. It bothered me for a few months and then I just accepted it after I measured the axles for squareness to the frame.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 04-08-2016, 12:40 PM   #8
gectisme's Avatar
Where are the pictures? I don't see them in my browser...
2016 Windjammer 3006WK
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, (not really used, left over from our truck camper). Equalizer E4 1.4k/14k WD Hitch. TST 507 TPMS. Furrion FOS48TA Observation Camera. Garmin RV-760 GPS. Honda 2000i Genny, PI EMS-PT30C.
MISSION COMPLETED!
gectisme is offline   Reply With Quote
Old 04-08-2016, 12:47 PM   #9
strat56's Avatar
I could see them in your quote of my post. Don't know why you can't see them.
Jack and Jan
Old 04-08-2016, 12:55 PM   #10
Have you noticed any abnormal tire wear? I would think that would be an indicator.
2003 GMC 2500 HD 8.1 & ALLISION TRANSMISSION
2000 SIERRA 30 ft FKSS
hondo is offline   Reply With Quote
axle
