Old 06-26-2014, 02:43 PM   #1
Axles too small?
Yesterday, I noticed that my 2012 Sandpiper 365 SAQ was sagging on the entrance door side of the trailer. I crawled underneath to see what the problem was, only to find that the right rear leaf spring was broken and the other three were flat as a pancake. Is there a recall notice on these axels that I'm not aware of? The dealer acknowledged they had "some problems" with the axels under these 5th wheelsÖ..none that they told me about when I bought it, however.
I've gone from very happy with Forest River products to extremely disappointed in about 24 hours.
Thank you for your help!
derrick is offline   Reply With Quote
Old 06-26-2014, 02:46 PM   #2
AquaMan's Avatar
Contact Sierra. They replaced my axles at the rally last year. Had one that was a little flat. I would bet yours is the Al-Ko, same as mine. They replaced them with Dexter axles.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 06-26-2014, 03:35 PM   #3
Confirmed. Al-Ko. Dealer sent email to Forest River along with pictures. I hope they replace them free of charge. I'll request Dexter axles, as well.
Many Thanks!!
Old 06-26-2014, 04:17 PM   #4
AquaMan's Avatar
Pretty sure Dexters are all they are using at the factory now. Many have had their axles replaced outside of warranty and the factory has covered and I would think more so in your case. Keep us posted.
Old 06-26-2014, 04:24 PM   #5
Will do. Thank you very much for your prompt replies.
Old 06-26-2014, 04:32 PM   #6
Witch Doctor's Avatar
Many Thanks!!
If you have lief springs you do not have alko axles... Could be wrong but alko are torsion not spring. Not that I know of. But it will not be the first time I'm wrong.
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-26-2014, 04:34 PM   #7
Don't believe the axles are too small, the springs are too small/light.
Old 06-26-2014, 04:54 PM   #8
AquaMan's Avatar
Al-Ko makes both styles of axles, as does Dexter.
Old 06-26-2014, 07:27 PM   #9
Thank you all for your thoughts & comments. My dealer is applying pressure with Sierra/Forest River. GVWR is 14,060. 6 ton axles are wholly inadequate. Sierra said that 6 ton was standard in 2012, but 7 ton was optional. Sierra is trying to place blame on dealer for not upgrading me prior to sale. We should achieve resolution in short order, but over the short term, I guess we have to endure the finger-pointing exercise. I really appreciate all of your help, however. I'm looking forward to getting this resolved quickly. I'll let you know how it turns out.
Old 06-27-2014, 10:16 AM   #10
Airdale's Avatar
Statistically speaking Iíll bet your axles are adequate and meet the minimum standards for your trailer. Remember, the GAWRs are set by the vehicle manufacturer after deducting the hitch weight.
If Iím incorrect and the axles are less than the certified GAWRs found on the trailerís certification label, all the trailer builder has to do is send you a new cargo label with enough deductions to get the axles in the ball park.
Airdale
Airdale is offline   Reply With Quote
axles
