Old 10-07-2012, 08:07 AM   #1
BAL 23216 Lock-Arm Stabilizing Bars
Has anyone used these? If so how happy are you with them? I am thinking about getting a few sets of these to help with shake. Will they work with the electric front jacks on my 2006 8280SS 5ver?
RickV is offline   Reply With Quote
Old 10-07-2012, 08:36 AM   #2
Their are companies that make complete sets. I made my own, and they make a HUGE difference. Pretty much a must-have in my opinion.
bakken is offline   Reply With Quote
Old 10-08-2012, 09:09 AM   #3
Helmsey's Avatar
I just installed a set on my landing gear this weekend. Took me longer to measure than to actually install them....VERY simple install
From a very basic "push test" they have locked the front of the 5er in place, but I think I will add a set to the rear. I will have to re-position my back stab jacks to make it work, and that is half the reason i got them....just to see if they would work on the rear jacks. I think with a little imagination I can get them to work. We will be camping this weekend so that will be a good test, will also know for sure if they are needed on the back.
I was going the "build my own" route, until I saw that Amazon had a set that was "used". I took a gamble (the price was right) and ordered them. Since they were being sold used by Amazon I was able to get my Prime benefits and had them in 2 days. I got the box and it had been opened, but the bag the mounting hardware was in had not. It looks like someone bought it, opened it, and returned it without installing it.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 10-08-2012, 09:59 AM   #4
I did the landing jacks first, and while that made a huge difference, I also think the back one will be necessary. That is one of my projects for the wintertime.
Old 10-09-2012, 06:50 AM   #5
Well I ordered two sets for the front. I was looking under my 5ver can I just cut the diaper at the mount points on the frame and reseal it or should unscrew the diaper?
Old 10-09-2012, 07:12 AM   #6
Don't know what you're calling a diaper, but they all mount on the legs and the outside of the frame & skirting. No cutting required.
Old 10-09-2012, 07:24 AM   #7
I am referring to the plastic underliner that covers the underbelly of the camper including the frame. Should I just mount through it?
Old 10-09-2012, 07:28 AM   #8
They mount directly to the bottom of the frame, you don't have to cut anything unless you just want to. The frame has a pc of 1x attached to it, then the Corplas and then an alum strip. You can mount over all of it.
Name:	Rear Anchor.jpg
Old 10-15-2012, 04:57 PM   #9
Got my stabilizers from the big brown truck this afternoon. I plan on installing them in the front. I should have no problem installing the ones that are front to back because there is a frame rail there but, the side to side ones may be a problem. There is a storage pan in the front and the side to side frame rail sits about 14" back from the jacks (the jacks are mounted to the front to rear frame rail on each side). The pan metal is only 1/16" thick if I mount to that wouldn't that create too much stress on the pan? I was thinking maybe I could put a piece of plywood in the bottom of the pan to make it stronger if necessary. Looking for suggestions.
Old 10-15-2012, 05:01 PM   #10
Pictures would help us understand what you're encountering.
