Old 05-17-2013, 06:44 PM   #1
BAL jacks will not hold any weight
they just unscrew as soon as I put some weight on them ..
any way to fix ?
subzeroschmidt is offline   Reply With Quote
Old 05-17-2013, 06:52 PM   #2
caper's Avatar
They are not to be used to jack the trailer. They are to be used to stabilize the unit. The jacks should not unscrew on their own.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 05-17-2013, 07:04 PM   #3
Twisty's Avatar
Try cleaning the threaded rod and the "nut". It needs to be dry enough to bind and hold when the jack is extended.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 05-17-2013, 07:05 PM   #4
rattleNsmoke's Avatar
X2. Somethings wrong there. They should be able to pick the wheels off the ground without unscrewing. As the OP said,they should not be used to jack the trailer. Run it up on boards until it's level then use the jacks to take the wiggle out of the trailer.
rattleNsmoke is offline   Reply With Quote
