Old 01-15-2014, 06:37 PM   #1
bearing packing
I have a 2012 Salem Cruise Lite with the zerk fittings to grease the bearings.
This is our first trailer and our first winter storage.
Planning a 2K mile trip in April this year.
Is it worth 200 to actually have the bearings repacked or is just using a grease gun and pumping grease in them enough?
Thanks in advance for the help
Mark B.
2021 GMC 1500
Anderson WDH
markb5900 is offline   Reply With Quote
Old 01-15-2014, 06:46 PM   #2
Ford Idaho's Avatar
Do you know what type of grease or how much they are packed in now?
I plan on repacking mine as soon as the weather allows because I do not know what or how much is in there.
Cheap peace of mind.
Old 01-15-2014, 06:49 PM   #3
They were packed last May when we bought the trailer.
have about 500 miles on it since we purchased it.
Mark B.
2021 GMC 1500
Anderson WDH
Old 01-15-2014, 07:23 PM   #4
Brother Les's Avatar
why would you pay someone to grease/pack your bearings? it is not that hard to do. 500 miles is not really any miles on the bearings. You have the zerks on there, just gently pump one or two handles in it and sleep well. Use grease that is made for what you are doing. My last camper I had for more than 16 years (averaged about 5-7,000 miles per year )and only pulled the bearings out twice in that time and hand packed them. Never had a problem with bearings.
Brother Les
Old 01-15-2014, 07:34 PM   #5
When you don't know how to do something, you pay someone to do it for you or you learn.
"learning" on my trailer is not what I consider to be a good thing to do. The consequences of me doing it wrong are too high.
Mark B.
2021 GMC 1500
Anderson WDH
Old 01-15-2014, 07:56 PM   #6
wayne in florida's Avatar
If I lived in Missouri i would swing by and do it for a case of beer...Very easy and im sure you could get a auto shop to do it for much less.
2006 Dodge Ram 2500 5.9 CTD
2012 Flagstaff MAC BR28TSC
2012 Days camped 23
2013 days camped 16
wayne in florida is offline   Reply With Quote
Old 01-15-2014, 08:28 PM   #7
rskrbina's Avatar
You might try going to youtube.com and do a search for "ez lube hubs". You will find it worth $200 to do it yourself. Just find the correct type of grease from the axle manufactures booklet. I have an Aluma utility trailer that also has ez lube hubs and grease them once a year whether they need it or not. Hope this helps.
Rudy and Jenny
2014 Flagstaff V-Lite 28WRBS
2013 F-150 Eco-boost 3.55
rskrbina is offline   Reply With Quote
Old 01-15-2014, 09:10 PM   #8
Very Eazy to do. Before we left on 3,000 mile trip with new trailer, we greased it up in 45 minutes
Steps we took
Mystik red JT-6 grease ( I think that is what we bought) as recommeded Dexter axle manual
Jack up TT wheel on frame one wheel at a time
Gently pumped grease into zerk while rotating wheel till grease was visible
On to next wheel.
Great peace of mind and 2,200 mile into our 3,000 trip we seemed to have lower temps at bearing hubs. Used 3 tubes of grease with 4 wheels ...don'tm know if this is typical
gtschmidt58 is offline   Reply With Quote
Old 01-15-2014, 09:22 PM   #9
LKicklight's Avatar
At one time RVGUY posted some very detailed instructions on wheel bearing maintenance, don't know where to find it at this time, but wish I had it to view one more time, preparing to do this the first warm weekend:
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 01-15-2014, 09:31 PM   #10
Infractee
EZ-Lubes are awesome! very easy to do, just make sure you are using the grease that axle/frame MFG recommends. S.L.O.W.L.Y. pump the grease in, especially if it is cold out. When our last trailer was brand new I used over half of a tube in the 4 axles when I got it home, factory (either Lippert or Rockwood) did not fill them as EZ-Lube recommended, if I had not checked them I feel they would have been destroyed rather quickly, also, two of them had the zerk fittings loose and one was off laying inside rubber cap.
GoodLuck!
Info library from Dexter on the EZ-Lubes
http://www.dexteraxle.com/resource_library_
RhoZeta is offline   Reply With Quote
Old 01-15-2014, 10:34 PM   #11
bearing grease
How does one know who the axel manufacturer is. The information on the included paperwork is no help. At least the Coachmen information is not. Is it stamped somewhere?
Thanks,
jim
jpaskell is offline   Reply With Quote
Old 01-15-2014, 10:41 PM   #12
Infractee
If you still have original paperwork it will list who made all of your equipment, frame, axles etc etc. Original Owners packet/paperwork will also have paperwork from frame builder talking about warranty an such. You should also be able to call Coachmen and find out with a VIN Check, they may even be able to send you a copy of the build sheet.
Old 01-15-2014, 10:59 PM   #13
bearing grease
Thanks RhoZeta,
I'll check my paperwork again. I probably didn't pay attention. There was a ton of it.
Appreciate the quick response.
Thanks,
Jim
Old 01-22-2014, 04:54 PM   #14
PhoneDude 8289's Avatar
Hand packing the bearings does three things. 1. You know they are packed correctly, 2. it gives you a chance to inspect brakes and drums, 3. you can adjust the brakes properly.
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 01-22-2014, 05:10 PM   #15
acadianbob's Avatar
I used the EZ-lube zerk for 5 years and 25,000 miles. Didn't worry about what grease was in there from the factory. Just bought NAPA's best wheel bearing grease and pumped until new grease came out. Finally had the bearings checked and packed at 25,000 miles. Zero trouble. Don't over-think it.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 01-22-2014, 05:32 PM   #16
KMP44's Avatar
Yes - if you have the tools, the space, and the experience of doing it frequently, re-packing the bearings is fairly easy. Teaching yourself on the job can indeed be very costly. If they are saying $200 to re-pack them, may be well worth it to avoid the hastle and the worry.
At 500 miles, all you probably need is to add a little grease through the fitting - not a re-pack. That is a DIY job - just make sure you have the recommended grease and don't over-grease. After your 2,000 mile trip it might be time to re-pack - depends on what the mfg recommends.
One other thought - don't know about where you are, but our dealer's service manager told me that if we brought the trailer to them for its annual state inspection, they pull one wheel to look at the brakes. He said I was welcome to stand there while they do it, as they also look at the bearings and make a recommendation on whether they think its time to re-pack the bearings. That gives me a chance to get their opinion and it saves me the hastle of pulling the wheel - which is more work than re-packing the bearings.
2022 Columbus 379MBC (Previous 2013 Rockwood Roo 23 IKSS)
2023 F-350 (Previous 2017 F250, 2005 F-150)
KMP44 is offline   Reply With Quote
Old 01-26-2014, 10:22 AM   #17
I am trying to find the right paper in the paper work to figure out what grease to buy.
Appreciate all the responses.
Mark B.
2021 GMC 1500
Anderson WDH
Old 01-26-2014, 10:26 AM   #18
MtnGuy's Avatar
There should be a sticker or a plate on the axles somewhere stating the manufacturer, along with the capacity and serial number of the axle.
Old 01-27-2014, 07:10 PM   #19
Texas Bohunk's Avatar
Just make sure you use a good high temp. bearing grease.
2014 V-Cross Platinum 365VTSB
2002 Frontier 305S bumper pull
2013 Dodge Ram 2500 4X4 6.7 Cummins Automatic Trans. AFE aftermarket air filter, Curt 24k slider hitch
Texas Bohunk is offline   Reply With Quote
Old 01-27-2014, 07:25 PM   #20
On this forum at the top of the page in the first green bar are links, third from the left is one called Library. Clicking on it will take you to an area full of useful information on axles and running gear!
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
