Old 05-06-2018, 02:48 PM   #1
Bearings and Grease
Just bought a new 29 foot trailer and wanted to check bearings for grease pulled the rubber caps out of the wheel cap and have the grease fitting so I gave each one 5 or 6 pumps from the grease gun but can't see any grease around castle nut yet ? Don't have the Super Lube Hubs just a fitting in the center should I be seeing some grease between rubber cap and
castle nut when I pump the gun a few times ?
hunter1022 is offline   Reply With Quote
Old 05-06-2018, 02:54 PM   #2
fonzie's Avatar
You have the eaze lube. It can take up to 1/2 tube of grease to fill when new. Keep pumping slowly while turning wheel by hand and grease should come out. It needs to fill the void between the two bearings.
EZ Lube Axles - Lubrication
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 05-06-2018, 02:55 PM   #3
keith52's Avatar
Do you have the Dexter EZ Lube axles?
2014 Chevy CC Duramax 4X4 Long Bed
2017 Cedar Creek 36CKTS
keith52 is offline   Reply With Quote
Old 05-06-2018, 03:14 PM   #4
Just have a fitting dead center of axel so I don't think I have the easy lube, is there a way to tell ?
Old 05-06-2018, 03:25 PM   #5
fonzie's Avatar
That is it.
Fonzie
Old 05-06-2018, 05:47 PM   #6
After more research they are the Easy Lube Hubs pumped the grease gun and turned the tires till I got grease coming almost a tube and a half, Thank you for the replys and help.
Old 05-06-2018, 06:24 PM   #7
Boondocking Only
ddbck's Avatar
It's very deceiving for sure. I do mine at the beginning of each camping season along with the brake adjustments. Yesterday each hub took between 30 & 32 pumps before I saw the old grease coming out.
2014 Shamrock/Roo 21SSL
Complete LED Lighting
Off Road Package
2010 F250 Lariat 6.8 V-10 w/Timbren SES
Custom Tunes by 5 Star Tuning
Boondocking Only
ddbck is offline   Reply With Quote
bearings
