Old 04-21-2016, 10:45 PM   #1
Bearings/Axles
Purchased trailer used several years ago. I grease bearings manually every year. I noticed these burn/rust marks every year. I sand the marks off with very fine emerycloth but the marks come back every year. I would replace all bearings and races but the axles have these marks. Any clue as to what it's from....? I was told trailer sat alot very little use.
mfMcFroggierPod is offline   Reply With Quote
Old 05-04-2016, 12:02 PM   #2
WJC
Maybe from heat, all though usually bluish in color, are your brakes running hot?
WJC
Dodge Durango 5.7 Hemi
2010 Primetime Tracer 3000 BHS Lemon
WJC is offline   Reply With Quote
Old 05-04-2016, 12:12 PM   #3
clr
It may be from rust inside the wheel bearings. You could try cleaning the bearings in a solvent but I would try replacing a bearing set for a wheel and see if that fixs the problem.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 05-04-2016, 12:24 PM   #4
Suspect bearing race may be turning on spindle. I have prick punched a few spindles to tighten the race so it won't spin. Should not be rust with all the grease on it. Check your inner bearing very closely for pitted rollers or race.
Old 06-04-2017, 01:40 AM   #5
Replaced all bearings a year ago. Same marks noted during my bearing inspection/repack.
Old 06-04-2017, 06:25 AM   #6
That high part of the spindle is where the seal rides. I do not think the bearing rides on that part. You can check that out by sliding the bearing on the spindle and seeing where it stops. If that is the case, those marks likely just come from the seal as it turns on the spindle.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Asrabbit is offline   Reply With Quote
Old 06-04-2017, 07:05 AM   #7
m35a2's Avatar
That might explain the axle, but not the rust on the bearing.
Do the hubs get hot when you pull the trailer?
-- My wife complains I never listen to her. Or something like that.
2017 Heritage Glen 368RLHBK Limited
2017 Ram 3500 4x4 Crew, 6.7 Cummins
m35a2 is offline   Reply With Quote
Old 06-05-2017, 12:57 PM   #8
Failure is my business
2Evil4U's Avatar
Judging by your eyeball in the first shot, it is on the bottom of the spindle and on the portion of the bearing that is lowest. It appears to be fretting. This is usually the result of a bad fit from the race to the spindle and contamination of some sort. (Most likely water in this case.) (FWIW, Orange means aerobic (with O2), and black is anaerobic, (without O2) both types will result in the same problems.) Scuffing it down with crocus cloth will only make the fit worse and will exacerbate the problem. Replacement of the parts with clean spindles and bearings with correct dimensions is the only way to eliminate it.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 24 Cedar Creek 40CBK
2Evil4U is offline   Reply With Quote
Old 06-06-2017, 08:39 PM   #9
That sounds expensive to replace spindles? Can new spindles be welded on vs new axles? Cost one vs other??
Old 06-06-2017, 08:42 PM   #10
Temps seem normal; I am just concerned about the marks.
Old 06-06-2017, 09:00 PM   #11
VinceU's Avatar
On a limb here but that marking may easily be a metal transfer of two dissimilar metals in very tight shaft to bearing fit. Eventually the shaft may no longer provide a tight fit for the bearing and will need to be renewed. Suggest use a micrometer to measure the shaft and check for proper clearance.
axle, bearings
