Old 02-08-2015, 02:04 PM   #11
Fulltime family RVer
Ok, good input so far. I appreciate the comments- keep 'em coming. I do actually know someone who does pool work and has various equipment trailers. I'll ask them.
The one trailer place that I know of- I'd be terrified to get into/out of their parking lot at my size. They were good with our pop-up and brake controller for the Durango, though!
Old 02-09-2015, 08:12 AM   #12
Witch Doctor's Avatar
Those I do. It's just the axles/wheels/tires area that are completely foreign to me.
You can take it to any mechanic you want to have that done, besides it will be cheaper then a rip off RV dealer. You could also jack your tire off the ground and see if you have any play by pushing the bottom or the top of the tire back and forth. If you have movement it is time.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 02-09-2015, 09:01 AM   #13
Kaadk's Avatar
So... it is painful admission time. I've owned the camper since July 2012 and is has been towed for somewhere between 10- and 15,000 miles. Maybe a little more, I'd have to check my notes.
The only thing that I've done was replaced the tires after about 4,000 miles.
Other than head shakes and finger wagging, can y'all tell me what I need to have done? I'm going to have to find a trailer shop in the area to do the work. I assume that for most of this, I'm better off not going to a RV dealer or service center and instead go directly to someone who does trailer work. Right?
I'm generally in the same place as you, except about 1 year newer (June '13). I've never really worried about the wheels other than keeping an eye on the tires. That is until my brother threw a bearing last fall. His failure to maintain his wheels resulted in a shredded spindle and a $1500 axle replacement. Now it's in my to-do list for the spring, but having never repacked bearings since grade 8 shop class I'm a little hesitant to do the job myself.
So from the other posts on here, can I assume that as long as there's no grease leaking it shouldn't be critical?
There's no use crying over spilt milk, unless it's on your keyboard.
Kaadk is online now   Reply With Quote
Old 02-09-2015, 09:26 AM   #14
bearings brakes and what else have i neglicted
I now believe in once a year inspection after the self adj brakes failed to adj and the shop found a broken spring and the adjusting whell riding around in the drum, all before the tt was 1 year old
Big Bill is offline   Reply With Quote
Old 02-09-2015, 10:42 AM   #15
RPAspey's Avatar
I take our TT in every year for the state mandated inspections. I always ask the mechanic to check the bearings. He ends up pulling and re-packing every other year or every third year. Ends up like 5-7k miles between re-packing.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 02-09-2015, 11:12 AM   #16
Ret E-9 Anchor-clanker
donanddona's Avatar
I totally agree with bearing/brake inspection. However it should be said that to have the bearings inspected the inner seals will need to be replaced. Bearing inspection includes remove, clean, inspect, repack. I do my own (ex-mechanic), local trailer shop wants $300+ to complete. Dealers want $$$$$$$$
donanddona is offline   Reply With Quote
Old 02-09-2015, 11:44 AM   #17
KMP44's Avatar
I have no idea about other states - but in NY all trailers need an annual inspection. But, unlike a car, there is no inspection sticker, so a lot of them never get inspected. And, the state sets the fee at $6. Turns out, if the trailer has breaks, the inspector is required to pull a wheel. Had my previous trailer inspected at several shops for 12 years - never even new they were supposed to do that.
But to the point, current dealer does that. Their deal is if you make an appointment for an inspection and tell them you want to wait on it, they do the inspection at a set time, and the owner is more than welcome to watch the mechanic pull the wheel to look at the brakes. They look at the bearings as well and give you a recommendation on when its time to repack. Then its your choice - do it yourself, have them do it, or just do nothing and hope. They don't just go by "every 12 months or 5,000 miles" - they show you what they see, and give you a recommendation. Since they are always busy, they don't seem to feel the need to push un-needed service work.
And, the service guys are pretty dead set against using the grease fittings on the easy lube axles. They see a lot of rigs with blown seals. There recommendation has been to not use the grease fittings. Just repack every couple years as needed.
So, if you can find a good shop that will let you look over their shoulder, you can learn a lot about what to look for. And even if you pay them to do the work, its a lot cheaper and a lot less headache than a bearing failure while traveling.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 02-09-2015, 02:43 PM   #18
The what else in the OP's post might also include lube of the suspension system, our Silverback has zerk fittings on the shackles.
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 02-09-2015, 03:31 PM   #19
In the State Of Virginia, You need to get your trailers inspected yearly and they put a sticker on. They have to pull your break drum and check the bearings all lights and the breaking system in general. The cost is $16.00 well worth the money just a PIA to drag the trailer to them. If they find a bad bearing or something you get a slip that say's what is wrong and why it failed and go's into the State Computer system. Get stopped and your pass due, big fine for the violation. They give you 30 day's to get the repair made. If you ever get stopped in Virginia the first thing they look at is your car and trailer dates of inspection.
Old 02-09-2015, 03:53 PM   #20
Timex's Avatar
There are plenty of YouTube videos showing how to repack the bearings. Some take the simple approach and some go the in-depth route. Either way, it is something that needs to be done. Kind of like painting the house or trimming the bushes(I hate to do either). If you have a buddy that can show you (hands on) how to do it, you'll be all set. And kick yourself for not learning years ago and paying the other guy all that money. I was the same way, and sometimes wondered if the work was even done. I haven't had a problem(yet) but I have peace of mind that it was done(by me)!
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
bearings, brakes
