Old 06-11-2016, 10:56 AM   #1
23ss ROOster
Wags2237's Avatar
Bearings, grease zerts
3 of the 4 zerts took grease fine, pushing out old grease and replacing with new. The 4th zert however, Struggled taking grease. I could barely squeeze the grease gun, a lot of resistance. I was able to get some new grease in and some old grease out before my hand went numb, but I don't think all of the old grease. I noticed the zert was a little loose. I also noticed when I first looked at zert, the old grease around zert seemed drier, just different than the other 3 zerts. Any ideas? Is it likely the bearings are bad? Where can I purchase bearings, seals for this Roo? Leaving on trip next Thursday. Thanks.
2012 23SS ROO
2014 Ford 4x4 F150 XLT 302A, screw, Ecoboost, 3.73, max tow, off road pkg., 36 gal tank, Ruby Red, tailgate step, Linex spray in, Truxedo bed cover, 30% front tint, Viper remote start, 1000 lbs WDH
Wags2237 is offline   Reply With Quote
Old 06-11-2016, 11:02 AM   #2
SeaDog's Avatar
You may not need new bearing or seals, I think I would first replace the grease zerk and see if the bearing will take grease and then proceed from there.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
bearings
