Originally Posted by CuzEd
Both sides have almost the exact same tire wear. I only took pictures of the left side(suspension, and right side tire) as it was easier to get under that side of the trailer. The axle has a slight bow up in the center and then both sides have a 4.6mm bow up(bent) on the ends. I would think that if I hit a pot hole or curb(which I haven't) it would be on one side of the trailer only.....
what about the other axle? Does it have the same bending/bow?
If it is the axle (correct term is Beam) that is the problem, it is best to talk to the manufacturer of that Beam and get a new one from them. Cheaper if you can change it out yourself. You can remove the hubs and brake assembly and put that on a new Beam.
I am not 100% convinced that the beam is incorrect, to where it is causes the same problem on each wheel/tire of that axle.
How do you have your tow hitch set up? is the camper level as it goes down the road. Having one end high or low could put a lot of pressure on one axle or the other and them mess with the tires to have a bad wearing pattern.
