06-20-2015, 12:19 PM
23ss ROOster
Best way to jack up 23ss ROO when changing tire?
Any experiences out there as to what type of Jack to use (will Jack from Ford F150 work)or purchase other? Where on frame to locate the jack? On axle? Appreciate your thoughts, comments.
2012 23SS ROO
2014 Ford 4x4 F150 XLT 302A, screw, Ecoboost, 3.73, max tow, off road pkg., 36 gal tank, Ruby Red, tailgate step, Linex spray in, Truxedo bed cover, 30% front tint, Viper remote start, 1000 lbs WDH
06-20-2015, 12:38 PM
Do not jack on the axel. You want to jack on the beefed up part of the frame next to the axel. I use a two ton hydraulic jack for my vibe. It is only 3500 lbs total. On the double axels you can drive one wheel on to some blocks that are high enough to lift the other wheel off the ground. They make small ramps for this purpose, just don't remember the name rite now.
Ontario
Current: 2019 Sunseeker 2290S
Previous (2012-2016): 2012 Vibe 6501
1 Prospector Canoe, 2 Mtn. Bikes & 4 Hiking Boots
06-20-2015, 01:46 PM
Use leveling boards, or the "lego type" leveling pads to make a ramp. I personally use the "tire aid" product. You pull or back the good tire up on it and it raises the bad tire off the ground. Just remember to loosen the lug nuts on the bad tire before elevating the good tire. Camping World and most rv parts stores sell the tire aid.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
06-21-2015, 10:42 AM
Georgia Rally Coordinator
I carry 2 2x8 boards that I level the camper with but come in handy to raise one wheel off the ground if I need to change . Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
06-21-2015, 10:49 AM
I've been carrying the Trailer Aid Plus. Works well, just bulky.
2019 Coachmen Freedom Express 281RLDSLE
2018 2500 HD Silverado
Equal-i-zer Hitch E4
06-21-2015, 10:52 AM
Only works for tandem axles.
06-21-2015, 11:58 AM
2016 Shamrock 183 Hybrid
Good one Coot
06-21-2015, 12:11 PM
Yeah, I know Neil, he's got the same trailer as I do, that's why I responded.
06-21-2015, 01:38 PM
I agree with jimandchris. I've had a TrailerAid Plus for several years and I'm convinced it's the best way to go. I had a blowout on one of my Chinese tires, when the Good Sam Road Service guy came to change it, I asked him if he wanted to use my TrailerAid Plus. He had never seen one. He used it and bought 3 for his service trucks.
Tom
06-21-2015, 06:00 PM
Rapid Jack (from Anderson Hitches) is the easiest way. Made in USA of recycled material. I also use their "camper leveler". Easiest way to level side-to-side that I've ever used. Lot less fuss and easier to stow than any other system, IMO.
Start watching this youtube video at the one minute mark.
06-22-2015, 06:38 AM
So y'all tell a guy NOT to jack by the axle, actually just under the spring works VERY well and will still equalize the weight between axles. You must jack under the axle to equalize the load OR the frame to pick the load off of both axles.
Think about it, when you got a double axle trailer the axles and tires are just barely rated to work together to carry the load, when you run it up on ONE tire and ONE axle on one side of the trailer ALL the load is on ONE tire and ONE axle. This is a very good way to BEND an already nearly overloaded axle and tire.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
06-22-2015, 08:38 AM
Originally Posted by Crusadernoob
So y'all tell a guy NOT to jack by the axle, actually just under the spring works VERY well and will still equalize the weight between axles. You must jack under the axle to equalize the load OR the frame to pick the load off of both axles...
He doesn't have springs, therefore what you describe is NOT an option.
06-22-2015, 02:41 PM
Toadman
We had a blowout on I-90 last year towing to northern Wisconsin on a Friday July 3rd, traffic was insane, wheel was on passenger side and I had about 20" of clearance between the guard rail and the 5th Wheeler. We called a tow service and he was there within 10 minutes. The repairman had a set of staggered 2x6 boards stacked and had me pull the front (tandem) axle onto the blocks he brought, leaving the rear wheel suspended. He had the wheel off before I could get the spare to him and we were back on the road within 10 minutes from the time he got there. I was needless to say, impressed. So long story short, the repair guy we had used these and they worked very well. Wish I had taken a pic, but I think you get the point.
06-23-2015, 09:05 PM
Regardless if he has springs, torsion or what ever, my point is NOT to put all of the weight of a double axle trailer onto one axle/tire, this is NOT the appropriate method to change a tire. Easy, yes, correct, NO! If it was designed to be able to hold the weight on one axle/tire it would come with one axle. How often do we see a 10k+ trailer on 5k axles. Already at max capacity, it's great a tire guy can change a tire in 10 minutes but all it takes is to get overloaded like that one time and bend the axle/spindle. My .02 worth.
06-23-2015, 09:10 PM
So what happens when you go up a curb or other obstacle and lift one wheel off the ground?? Automatic bent spindle? There is a safety factor designed into the spindles. Just because it says 5k doesn't mean that if you put 4000# on one spindle it will bend or break.
06-23-2015, 09:18 PM
When you have a blowout, most are pulled at least a half mile before even noticed. All the weight on one side is on the single axle for entire time at highway speed. I bought a tpms just so I know, been there, done that.
Cheers from Alberta Canada
2011 Flagstaff 8526RLWS 5th Wheel
2011 Ford F250 4X4 Crewcab Superduty 6.7L Diesel
B&W 3300 Hitch for Ford 5th Wheel Prep package
06-23-2015, 09:37 PM
We carry a Trailer Aid. Used for both our horse trailer and TT. Works great. Make sure you get the wider one. Ours has ramp on both sides. Easy Peasy to use!
