Old 12-04-2014, 08:20 AM   #11
mark0224's Avatar
Some trailers it says not to use a jack to raise wheels for removal. If you have one of these and have a flat, you pull the trailers good tire up on some wide boards till the flat one comes off the ground or use one of these
Putting a bunch of blocks under a bottle jack works for stability but to raise a wheel off the ground is not real safe.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 12-04-2014, 09:00 AM   #12
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
I purchased one of these (Trailer Aid PLUS) but it doesn't raise my other tire nearly enough to be off the ground. That's when I came up with the "cradle".
Robert & Estha Shiflet
'17 Cardinal 3456RL - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 & 2013 & 2014 & 2015 & 2016 & 2017 & 2018: 834 ~ Nights Camping 2019: 14
rjshiflet is offline   Reply With Quote
Old 12-04-2014, 10:46 AM   #13
Ret E-9 Anchor-clanker
donanddona's Avatar
I think they have modified the "Trailer Jack". I bought an old one 4-5 years ago and yes it did not lift nearly enough. Since then I have seen it in the RV parts section with an added block (black) in the saddle area. Not sure of it and won't buy another to find out. I'm sure some during a flat tire condition some bottle jacks may not fit to lift but I haven't been there yet "knock on wood".
donanddona is offline   Reply With Quote
Old 12-04-2014, 07:50 PM   #14
Platokidd's Avatar
I use this from farm and fleet
Using the u bolts on the axle as a jack point .
Thought the following 2 links were interesting too
Safe Jack - Bottle Jack Accessories
Kojack Hydra Jack | Caravan Jack | Hydraulic Jacks - Purple Line
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
R.I.P. Luke the campin dog
Platokidd is online now   Reply With Quote
Old 12-04-2014, 08:37 PM   #15
I jack on the suspension framework between the axles and lift both wheels at the same time. Made a different kind of attachment for a bottle jack.
ID:	67125   Click image for larger version
ID:	67126   Click image for larger version
Old 12-04-2014, 08:52 PM   #16
Boss Hoss's Avatar
Originally Posted by rjshiflet View Post
This is what I came up with for safety (to keep the axle from slipping off the bottle jack) and to prevent the bottle jack from denting the axle due to too much weight concentrated in one little area. I was having a gate and electronic opener built, and I sketched the design out on a piece of scrap paper. The welder accepted the challenge and the next day he handed me the completed piece.
Just slide the rounded end over the bottle jack and cradle the "U" shaped piece under the axle and the weight is dispersed over the 3 1/2 x 3 1/2 inch area rather than a one inch round portion of the jack.
Works like a charm!!
You get 10 McGiever points for that one!Note taken.
2013 Palomino 30ft. of Pure Bliss at 5400#-and then we have this 14 ft.Sea Eagle that I tote around for my wife and son.Michigan State Parks are The Best !:thumbsup
Boss Hoss is offline   Reply With Quote
Old 12-04-2014, 09:09 PM   #17
...Just slide the rounded end over the bottle jack and cradle the "U" shaped piece under the axle and the weight is dispersed over the 3 1/2 x 3 1/2 inch area rather than a one inch round portion of the jack. Works like a charm!!
As long as it is not used on a torsion axle, it should work great!
Old 12-06-2014, 08:11 AM   #18
jriddering's Avatar
Gotta make one of those
Jim and Carol
2012 Crusader 290RLT
2010 Ford F-250 King Cab Diesel
Harley Davidson Edition
jriddering is offline   Reply With Quote
frame, jacks
