Old 11-29-2014, 04:10 PM   #1
jriddering's Avatar
Bottle Jacks for frame
I want to get some bottle Jacks for tire changing and stabilizing. It's about 24 inches from the ground to the frame. Where do you buy that tall of a jack?
Sent from my SM-G900V using Tapatalk
Jim and Carol
2012 Crusader 290RLT
2010 Ford F-250 King Cab Diesel
Harley Davidson Edition
jriddering is offline   Reply With Quote
Old 11-29-2014, 04:25 PM   #2
Ford Idaho's Avatar
Harbor Freight.
Maximum Lift Height (in.) 41-3/4 in. Minimum height (in.) 23 in.
8 Ton Super Heavy Duty Long Ram Hydraulic Flat Bottom Jack
Old 11-29-2014, 04:59 PM   #3
jriddering's Avatar
If you had a flat, could you get that one under frame?
Jim and Carol
Old 11-29-2014, 05:08 PM   #4
mcnabbwr's Avatar
For me that tall of a jack would be too unstable on uneven terrain, I use a standard height ten ton jack. If I need more height I utilize my leveling blocks which are wider at the base allowing for a more stable arraignment.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 11-29-2014, 05:15 PM   #5
X2
This is what I use. A jack stand/bottle jack combo and I block it underneath for more height and stability.
rana is offline   Reply With Quote
Old 11-29-2014, 05:20 PM   #6
jriddering's Avatar
Originally Posted by Yarome View Post
X2
I like this setup. A couple of stabilizer blocks and it would be perfect
Jim and Carol
Old 11-29-2014, 05:46 PM   #7
Ret E-9 Anchor-clanker
donanddona's Avatar
I use two eight ton hydraulic jacks for the stabilazation under the front axel. Initially, I level the 5r, then position (lower) the electric rear stablizer (raising the rear about 1" to 1-1/2", then put the bottle jacks on blocks (3 blocks used for 15" tires), screw the center post up to meet the frame and then lower the rear stablizer about 1/4" to 1/2". If needed I could jack the hydraulic jacks up a bit but staying in one spot for close to a month I think it would bleed minimal pressure. And, yes I also use it for removing tires.
donanddona is offline   Reply With Quote
Old 11-29-2014, 05:59 PM   #8
rattleNsmoke's Avatar
How about a 10" X 10" railroad tie and put it under a standard heavy duty bottle jack? That would give you plenty of height I would imagine.
rattleNsmoke is offline   Reply With Quote
Old 12-04-2014, 06:12 AM   #9
I lift from the axle, as do the companies that provide tire service. I would never lift from rv chassis. Too much twist and instability on uneven surface or high winds.
biznsa is offline   Reply With Quote
Old 12-04-2014, 07:03 AM   #10
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
This is what I came up with for safety (to keep the axle from slipping off the bottle jack) and to prevent the bottle jack from denting the axle due to too much weight concentrated in one little area. I was having a gate and electronic opener built, and I sketched the design out on a piece of scrap paper. The welder accepted the challenge and the next day he handed me the completed piece.
Just slide the rounded end over the bottle jack and cradle the "U" shaped piece under the axle and the weight is dispersed over the 3 1/2 x 3 1/2 inch area rather than a one inch round portion of the jack.
Works like a charm!!
Robert & Estha Shiflet
Cardinal 3456RLX - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 & 2013 & 2014 & 2015 & 2016 & 2017 & 2018: 834 ~ Nights Camping 2019: 42
rjshiflet is offline   Reply With Quote
frame, jacks
