Old 07-20-2012, 09:40 AM   #1
Brake adjustment
I have a 2013 Wildwood 281QBXL. I read that Alko recommends brake adjustment after your first 200 miles. Is this necessary? Any tips? It is a two axle trailer. Do all the brakes have to be adjusted perfectly the same? If there is any variation, would it cause the trailer pull to one side?
Srfdawg81 is offline   Reply With Quote
Old 07-20-2012, 10:37 AM   #2
Dave_Monica's Avatar
I've checked but not had to adjust the brakes on our current camper. I did have to back off on the brake adjustment on our previous TT as they were too tight.
You can jacked one side at a time to check...you want to hear light contact of the brake shoes on the drum. You wouldn't want a situation where one side of the camper is locking up and the other side isn't braking at all.
Dave
Old 07-20-2012, 11:48 AM   #3
The reason for the adjustment after 200 miles, is due to the brake shoes when applied are "seating" to the contour of the brake drums. The shoes and drums are not perfectly matched when manufactured and therefore the shoes will wear more in some places than others. After about 200 miles, they should be pretty well "matched" to the drums, hence requiring a little adjustment. The trailer brakes will react to "pulling" to one side or the other just like a car/truck if improperly adjusted.
Old 07-20-2012, 12:00 PM   #4
MtnGuy's Avatar
No, but they should all be close to the same.
I tighten my star wheel until I can barely move the tire & wheel, then back it off 6 "clicks", until the wheel turns fairly free. I can still feel the shoes rub some at the "high" spots. I can give the wheel a whirl, and it will rotate 2, 3 or 4 times before stopping.
Old 07-20-2012, 12:56 PM   #5
Twisty's Avatar
Find out exactly which style of brakes you have.
Mine have a linkage which turns the adjusting screw as the shoes wear just like automotive drums.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 07-20-2012, 02:36 PM   #6
TURBS's Avatar
Another "cool" trick is to adjust brakes the hook up to the tv and manually apply brakes a few time then check adjustment again.
Normally they'll be a little loose again.
Try it once.
Old 07-20-2012, 04:12 PM   #7
Are you sure about that? I think you'll find that they're self-adjusting.
Dave
Old 07-20-2012, 04:19 PM   #8
Dave
From the FR brochure:
Running Gear
◦Super-Lube Hubs
◦Galvanized Steel Wheel Wells
◦Independent Torsion Suspension System (N/A Sport models)
◦Leaf Spring Axle(s) (N/A Select models)
◦Radial Trailer Tires
◦Nev-R-Adjust® Electric Brakes, All Wheels
◦Tough, Powder Coated Frame
◦2-5/16" Coupler
Old 07-20-2012, 04:34 PM   #9
Running Gear
◦Super-Lube Hubs
◦2-5/16" Coupler
Well, I stand corrected. I guess this must have been a change for 2012?
Dave
Old 07-20-2012, 04:58 PM   #10
Twisty's Avatar
Dave
I consider it self adjusting.
You never read about adjusting automotive drum brakes...
2012 Surveyor SV264
NW Oregon
brakes
