Old 11-08-2014, 09:33 PM   #1
elika63's Avatar
Brake Controller
Purchasing a TT for the first time. Need to know what brake controllers are the best (not necessarily cheapest). Also, I heard some dealers will only install brakes on one axle instead of both. Is that something they typically do or is it based on how the trailer comes from the factory? Thanks!
elika63 is offline   Reply With Quote
Old 11-08-2014, 10:01 PM   #2
asquared's Avatar
Trailer brakes are installed at the factory. For a brake controller you want to get a proportional brake controller not a time based controller. Prodigy P2 or prodigyvp3 are very good. I have used the p3 with one of my old TV. It worked well, it DoD have a defect but manufacturer immediately sent me a replacement. No issues with the replacement.
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 11-08-2014, 10:20 PM   #3
elika63's Avatar
Thanks asquared. What all do I need to purchase? I'm assuming the correct wire harness but not sure beyond that.
Old 11-08-2014, 10:35 PM   #4
asquared's Avatar
Does your TV have the tow package (ie tranny cooler, prewired for brake controller etc)? If so you order the correct wiring harness for your TV. It will be plug and play. If you get the universal wiring harness its a bit harder as it doesn't just plug in. You will then pick a spot to screw if to your dash. I usually pick the bottom of the dash of to right so it's out of the way when climbing in. Took my dh 30 min to install and he's not all that handy (but getting better).
2014 Sabre 34REQS-6
Old 11-08-2014, 10:38 PM   #5
elika63's Avatar
Yes, I'm prewired and have both the oil tranny cooler and max tow package. So I just need to purchase the wire harness for my truck and the unit, thanks again!
Do most, or all, TT have brakes on both axles or just on one? I have heard of brakes only on one axle.
Old 11-08-2014, 10:39 PM   #6
Phat Phrog Stunt Crew
elind's Avatar
The prodigy P2 is sold with what it needs for each truck. Later GMs are hard wired with the wires under the dash labeled for use. Others have plug in wiring harnesses to plug and play. Either way it's simple.
By the way, I have a GM mount P2 controller for sale that I used 2 months until I bought a new truck. PM me.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 11-09-2014, 01:05 AM   #7
GreenImp's Avatar
Send a message via MSN to GreenImp
For the purposes of this post, the term "integrated" will be referring to being tied into the vehicles hydraulic system (not "built into the dash").
You did ask about the "best" brake controllers, and while the Prodigy P2 and P3 are certainly the king of their class of controllers (don't even consider a time based unit), there is something better. An "integrated" brake controller is a far better solution than any inertia based controller like the P2 and P3. It is the only way for the trailer to work 100% seamlessly (smooth) with the tow vehicles brakes, and does so in forward and reverse, at speed or while crawling into your favorite site. Unfortunately, they are not as widely available as standard controllers. Both the MaxBrake and Brake Smart controllers were integrated into the vehicles hydraulic system, but neither is being produced any more (not enough people share your "best and not necessarily the cheapest" point of view). You may be able to find a used one or possibly an NOS unit. Otherwise, there is a new controller on the market (earlier this year?) called the DirecLink. I have no personal experience with it, but it is "integrated" with the tow vehicles brakes via the on board computer (OBII). Vehicle manufacturers have finally caught on to this supremacy as well, and are now offering computer controlled integrated brake controllers (with the added bonus of being built into the dash at the factory).
My post is sure to be followed by those defending their precious Tekonsha Proportional controllers, but rest assured...if you want "the best", then you want an integrated controller. Otherwise, the Prodigy P2 or P3 is the next best thing, and good enough for most.
http://www.direclink.com/direclink.html
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2021 Solitude 310GK w/FBP
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 11-09-2014, 01:55 AM   #8
Flagstaffer06's Avatar
I recently changed to a P3 controller and it works awesome. Very smooth. I think you will find that a large group of folks are using the Prodigy series controllers.
The P2 and P3 are identical in performance. The only difference is the P3 can also work on electric over hydraulic brakes if you had a trailer that was so equipped. Your travel trailer will have only electric brakes. Also the P3 controller has a scrollable menu and led menu. I was going for a P2 but, found a P3 on ebay used once that I couldn't pass up.
As others have said, purchasing the wire for your specific vehicle will make things quick and easy.
You can't go wrong with the Prodigy P2 or P3 though. Good luck!
2012 Keystone Sprinter
Still sticking around for the good people and advice.
Flagstaffer06 is offline   Reply With Quote
Old 11-09-2014, 01:57 AM   #9
elika63's Avatar
Brake Controller
Thanks guys! Appreciate the thorough responses. I think I'll go with the P3 but that DirecLink looks awesome (although a tad pricier). I'm already dropping $2,500 on a ProPrime P3 WD hitch!
Old 11-09-2014, 04:29 AM   #10
Witch Doctor's Avatar
You should have brakes on all axles. Who told you that BS.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-09-2014, 10:09 PM   #11
GreenImp's Avatar
The P3 is a good choice. FYI...somebody posted a P3 in the classifieds here yesterday for $100.
Old 11-09-2014, 10:46 PM   #12
I have the Primus IQ by Tekonsha and it has worked well for me. It is also a proportional brake controller and will save you some money over the P2 if you don't need trailer features like electric over hydraulic brakes or 4 axles.
keith_h is offline   Reply With Quote
Old 11-09-2014, 10:58 PM   #13
Taybrynn's Avatar
Direclink worked better for me than the prodigy . Way smoother braking on my big 5er ... If uses the obdii port
2015 Wildcat 337FB
2006 GMC Sierra 3500 SLT DRW - Duramax
Taybrynn is offline   Reply With Quote
brake control, controller, brakes
