Old 06-22-2015, 08:30 PM   #1
Brake controller question
Hi I have a 2015 Chevy Silverado with the factory installed brake controller. When applying the brakes manually it will not lock up the brakes even with the gain set all the way up. Should my trailer brakes be adjusted?
gserve is offline   Reply With Quote
Old 06-22-2015, 08:33 PM   #2
davel1971's Avatar
be something to look at, or see if they are working at all. Make sure they are responding to the controller
David & Lynn
Old 06-22-2015, 08:40 PM   #3
You may have to install a fuse or relay. Had to do something like this for a 2012 Silverado. Check your owners manual.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is offline   Reply With Quote
Old 06-23-2015, 12:37 PM   #4
The brakes work. They won't lock up when increasing the gain to the max. That's why I think they need to be adjusted.
Old 06-23-2015, 01:04 PM   #5
brookstone345sa's Avatar
You might want to pull one hub. Check for grease on inside flat surface. If you have greasable hubs sometimes the grease seals go bad and contaminate everything. Ask me how I know, had same experience
brookstone345sa is offline   Reply With Quote
Old 06-23-2015, 05:05 PM   #6
This is a year old trailer that the brakes have never been serviced.
Old 06-23-2015, 07:14 PM   #7
Crockett's Avatar
all the more reason to look. I service a rental fleet. 40% had grease contamination at less than one year. oem grease needs replacement asap IMO
Crockett is offline   Reply With Quote
brake control, controller, brakes
