Old 05-20-2013, 03:16 PM   #1
Newbie
pg_rider's Avatar
Brake controller set to 11 (out of 13) - do my brakes need adjusting?
Just started our 2nd season with our Rockwood 2306. I've always felt like the trailer brakes were never quite strong enough, so I've slowly been increasing the setting on my brake controller since last season (Prodigy Primus IQ). I'm currently at 11 volts and the trailer brakes don't even seem close to locking up. I believe the controller adjustment only goes to 13 volts.
So... is it possible my trailer brakes need servicing? I've put probably 4000 miles on them and have never had them checked (shame on me, I know). Anything else I should look into? Should I try the max (13 volt) setting and see if they lock up then?
Assuming I need to adjust the brakes, is this something I can do myself? I'm pretty handy and do most of my car and truck service myself. Prodigy offers these seemingly simple instructions:
Brakes should be adjusted after the first 200 miles of operation when the brake shoes and drums have “seated” and at 3000 mile intervals, or as use and performance requires. The brakes should be adjusted in the following manner:
  1. Jack up trailer and secure on adequate capacity jack stands. Follow trailer manufacturers recommendations for lifting and supporting the unit. Check that the wheel and drum rotate freely.
  2. Remove the adjusting hole cover from the adjusting slot on the bottom of the brake backing plate.
  3. With a screwdriver or standard adjusting tool, rotate the starwheel of the adjuster assembly to expand the brake shoes. Adjust the brake shoes out until the pressure of the linings against the drum makes the wheel very difficult to turn.
  4. Then rotate the starwheel in the opposite direction until the wheel turns freely with a slight lining drag.
  5. Replace the adjusting hole cover and lower the wheel to the ground.
  6. Repeat the above procedure on all brakes.
2012 Rockwood 2306
2007 Honda Ridgeline tow vehicle with Equal-i-zer and Prodigy P2
pg_rider is offline   Reply With Quote
Old 05-21-2013, 02:14 PM   #2
Newbie
pg_rider's Avatar
Anyone? lol
2012 Rockwood 2306
Old 05-21-2013, 02:23 PM   #3
cat1956's Avatar
Not sure what.But something don't seem right.I have an 08 21fb with many miles on it and I an still @ 4 out of 10 with my controller.
cat1956 is offline   Reply With Quote
Old 05-21-2013, 02:31 PM   #4
DAISY BOYKIN's Avatar
Had the same problem-------------
I had the same problem right out the box with a new fifth wheel. After six months of repairs here and there, finally found a bad brake magnet. There is a reading you can take at each wheel for the magnet to see if it is bad. Check your Alco owners manual if you have Alco system. It will tell you what each wheel magnet should read in OHMS
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 05-22-2013, 06:15 PM   #5
one thing to be aware of with the prodigy or other pendulum style controllers, they are very touchy about the ANGLE they are positioned in under your dash. It's easy to see what i mean.. with the foot on the brake, simply tilt the controller to a slightly different angle. the vt will change dramatically.
and yes. trailer brakes do periodically need adjusted.
you got the instructions pretty much 100% already.
jack up a side, spin the wheel while turning the adjuster wheel from the back side till it starts to drag, then back off a hair (crash course, there are likely posts you could search to get more detailed description but that will work).
melk-man is offline   Reply With Quote
Old 05-22-2013, 06:26 PM   #6
wyo700's Avatar
First thing right away I would check the adjustment on the brakes. That sounds like the problem to me especially if you haven't checked them yet. And if you had a brake magnet bad I think your BC would tell you something is wrong. I have a p3 mine did not sure if yours has diagnostics though.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
