Electric brake issue
Regarding my recent purchase of a used 2014 Palamino Columbus fifth wheel:
I'm sorry but I cannot locate the thread from yesterday about my problem getting a drum off one of the electric brake assemblies. My last post from yesterday I said I would take the suggestion to use the brake adjuster to see if that helped removing the drum.
Well, I did that this morning and I was able to remove the drum. However, the rear bearing and seal did not come off with the drum and now I cannot remove the bearing. It's moving freely like a bearing should but I just can't pull the thing off. The rear seal moves easily but of course I can't remove the seal until I remove the bearing. I have not tried to remove by force as I don't want to risk damaging the race or any other part of the axle.
This is the fourth wheel I've inspected after buying a used fifth wheel. I replaced two of the magnets due to exposed wiring on them. Lots and lots of grease. I suspect the previous owner just put the grease gun to them rather than doing an actual inspection and repacking.
