Old 06-18-2012, 07:08 PM   #1
Brake noise when backing up (Solved)
When I was backing into my storage spot the other day, I heard a very load grinding noise in the rear axle/hub/brake area. So tonight I finally got around to raising the wheel to rotate the tire. Rotating it foward seem's to be fine. Heard a little rubbing of the brake shoe's. But when I tried to rotate it in reverse it would turn with resistance and would lock up. I could rotate it foward, then I tryed to rotate in reverse it would rotate a small amount and lock up again. I was not able to remove the hub at this time. Was just hoping someone could give me a idea, before I call the dealer. (Not wanting to deal with them. )
I have a Coachman with a Lippert Axle 3500#
All above was done not hooked up to the TV.
2014 Coachmen Freedom Express 281RLDSLE
2008 GMC Sierra 2500HD
Prodigy 3 Controller
2009 (11), 2010 (18), 2011 (29) 2012 (42) 2013 (53), 2014 (1 so far)
mike7431 is offline   Reply With Quote
Old 06-18-2012, 07:42 PM   #2
sherdep's Avatar
are you sure it is a Lippert and not a Al-Ko axle assembly?
if it turns forward but not backwards very well - hard to tell without taking it apart to get a looksy
if it is just the axles and the trailer is not under warranty - and trailer place can look at the axles and probably alot less then the RV dealer will charge.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 06-18-2012, 07:58 PM   #3
Positive on the Lippert Axle. Crawled under to get serial and model number. Has Lippert label all over it. I do have extended warrenty, for what thats worth. (I'm sure for some reason it won't be covered though.)
Old 06-18-2012, 08:04 PM   #4
DDC
DDC's Avatar
Broken or loose spring ,trailing shoe is grabing.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 06-18-2012, 08:28 PM   #5
Thats kind of what I was/am hoping it is. I'm going to go back up tomorrow and pull the hub and look. Thanks.
Old 06-20-2012, 07:06 PM   #6
Spring and adjusting wheel were loose. Fell right out when I removed the brake drum. I will have to get drum truned and get new spring, it was almost cut thru.
brakes
