Old 08-26-2018, 09:31 PM   #1
BuzzWolfAR's Avatar
Brake question
I have a 2018 Cedar Creek Silverback 29ik. Greased the bearings today -- love the easy lube system.
Front axle tires spin freely. Both rear wheels have a slight tension from the Dexter Never Adust brakes and will only do 2 or 3 revolutions before stoping.
Do I only have electric brakes on the rear axle? Axles are Dexter 5,000 pound, I think.
Just trying to confirm everything is ok.
Buzz & Jo Wolf
5er: 2018 Cedar Creek 29ik
TV: 2014 F350 Diesel
BuzzWolfAR is offline   Reply With Quote
Old 08-26-2018, 09:45 PM   #2
Who Dares, Wins
doc73's Avatar
No you should have brakes on all axels.. Two thoughts, the other set of brakes are just slightly less adjusted or a rear seal was pushed out and you greased or brakes. The ez lubes are okay but can cause rear seal low out. This let's you pump the grease into your drums. Lippert puts them on their axels and does not recommend using them (well their tech guys do not).
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 08-27-2018, 05:13 PM   #3
BuzzWolfAR's Avatar
Pulled the hubs today, no grease past the seal, and some brake dust in there.
Must just be adjusted a little bit looser. Worth looking at, glad I have no issues.
Buzz & Jo Wolf
Old 08-27-2018, 05:14 PM   #4
BuzzWolfAR's Avatar
Looks good huh.Click image for larger version
Buzz & Jo Wolf
Old 08-27-2018, 05:53 PM   #5
Who Dares, Wins
doc73's Avatar
Originally Posted by BuzzWolfAR View Post
Looks good huh.Attachment 184607
Good. Grease on the brakes would be no fun!
2015 Chevy HD D-Max
Old 09-26-2018, 09:53 PM   #6
I have a dodge 1500 4x4 with a diesel it has a auto braking system set up but you need to know type of brakes I have a wildwood x lite what type brakes does it have
Coolhand1 is offline   Reply With Quote
Old 09-26-2018, 10:04 PM   #7
SailorSam20500's Avatar
I had the "over adjust" issue on two of my wheels. One would only do about a half rotation. I had un-adjusted them a couple of times and they kept tightening up. Decided I was just not happy with them and just had disk brakes installed. No more problem.
Installer who did the brakes noted that there was a period where the seals that were being used just were not up to spec and a lot of them leaked - EZ-Lube or not. Also, before my job, he had done a 3 axle 5ver and 5 of the wheels had leaking seals.
BTW, the trailer stops a LOT faster now. Side benefit - if the seal does leak, it only contaminates one side of the rotor - so the braking is still at 50%.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
