Old 06-17-2016, 06:07 PM   #1
Professional Curmudgeon
Brake shoes adjusted too far in
and I can't get it to adjust out!
Ok, 10 inch drums on Lippert axles. Removed the two plugs at the bottom rear of the backing plate. Needed to adjust the shoes out just a little, instead they got adjust in - a lot.
Can't turn the drum at all. The adjuster wheel is not a star, it is more like a pawl, it's easy to adjust out, but I can't find anything to push against to adjust in. There is a silver piece that is spring loaded and sits on top of the adjuster. I assume it's to keep the adjuster from loosening up during use.
What am I missing here? I could use some help here before I get out the pry bar and pry the drum and brake shoes out at the same time.
2002 Forest River Flagstaff 8528RLS
2014 Coachmen Catalina 253RKS
2016 Keystone Summerland Mini 1750RD
2012 F250 Lariat 6.2L Crew Cab FX4
wrvond is offline   Reply With Quote
Old 06-17-2016, 06:58 PM   #2
What you're calling the "silver piece" is the preventer (I don't recall the technical term) that stops you from reversing the pawl. It's a bit awkward, but hold the preventer off the pawl with a small screwdriver while you turn the pawl with another.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 06-17-2016, 07:05 PM   #3
Thanks. I have tried that, but my problem is the teeth of the pawl only point toward the tightening direction. Trying to turn it the opposite direction results in the screwdriver blade simply sliding up and off the "ramp" of the pawl.
I wish I could get a photo to post.
I've looked it up on Lippert's YouTube channel. Their example only has one hole (mine has two), and the brake spoon they use easily spins the wheel both directions.
So frustrating...
Old 06-17-2016, 07:38 PM   #4
Carknocker Family
Ida Ratherbe Camping's Avatar
This is the tool you need instead of screw driver to turn adjustment wheel. You will still need to hold off locking pawl with small screw driver to loosen.
Drum brake spoon
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 06-17-2016, 08:43 PM   #5
Thanks for the help guys. I got it. Ended up removing the entire drum and backing plate. This allowed me to put it on the bench and shine a light in from another angle so I could see and work at the same time. Turns out the adjuster was under too much tension to easily spin back in, once I was able to tap a screwdriver with a small hammer, I got it moving and spun it in easily. Apparently the reason it is a ratchet wheel rather than a star wheel is these brakes (according to Lippert) are self adjusting. Go figure.
Anyway, thanks sent out to both of you!
Old 06-18-2016, 09:23 AM   #6
Head Rambler
Thanks for coming back and letting us know what you found and how you fixed it.
Also, thanks for letting us know how they're designed and what to look for.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 06-18-2016, 04:14 PM   #7
Drum brake spoon
X2. Always carrying a brake spoon. Half the time you can get lucky with a screwdriver but tough job.
Filterman is offline   Reply With Quote
brakes
